Hot Rods No pump rod in 8ba
Discussion in 'The Hokey Ass Message Board' started by Boden, Dec 25, 2019.
  1. Boden
    Boden
    I’m running a electric fuel pump that will be flowing through my stock pump to make it look like it’s running the mechanical pump. But since I am not running it I will not have the pump rod in there. Do I need to plug the oil hole in the guide or just leave it open. Just making sure before I bolt everything down
  2. In the books i have read,,they say to plug it,,,,,seems logical.
    Tommy
  3. 19Fordy
    19Fordy
    I removed the fuel pump rod from my 8BA 15 years ago when I installed an electric fuel pump.
    I did not pug the hole and have had no problems or lowered oil pressure. There has been much debate about this on Fordbarn with lots of differing opinions. Peruse this info.
    https://www.fordbarn.com/forum/search.php?searchid=13963160 With push rod removed a greater amount of oil splashes up into the
    valley of the engine. I guess you could plug the hole to eliminate the splash. If you do decide to plug it,do it in such a way that you don't damage bearing just in case you ever want go back to a mechanical pump. I decided to make an oil fill pipe with a cap extension that reaches down to the top opening of the bearing to reduce splash. Here's some photos.
    cederholm, my2nd40, LOU WELLS and 2 others like this.
  4. Boden
    Boden
    What’s wrong with oil splashing out of the guise?
  5. BamaMav
    BamaMav
    from Berry, AL
    If I was going to run an electric pump, I'd just block off the mechanical spot with a plate or something. Two less fuel line connections to worry about leaking, and fuel won't leak past the pump diaphragm and get in the oil.
  6. clem
    clem
    Why not just shorten your pushrod so it doesn’t work and leave it in there.
    It wouldn’t take much, (as they wear, they stop working anyway).
    That would solve both problems.
    A couple of years ago mine stopped working due to wear, so we made up a new one that was adjustable - threaded bolt in the original cut down rod, with a lock nut. Next time it plays up, we can adjust it on the side of the road........
    alanp561 likes this.
  7. Boden
    Boden
    Well if I shorten it so it’s just sitting in there would it be bouncing around?
  8. clem
    clem
    I can’t see any reason why not, as long as you only shorten it enough to just touch on maximum stroke.
    Others on here might wish to comment.
  9. Hank37
    Hank37
    Just cut a short section off fuel pump rod and clean block and apply silicone sealer around rod and let it set up.
  10. Flathead Dave
    Flathead Dave
    from So. Cal.
    Just block it off. You'll be fine.
  11. 19Fordy
    19Fordy
    Boden, Easiest thing to do is just remove the push rod, label it as to what engine it is for and put it on the shelf.
    Those push rods are hardened on one end and are of various lengths for different year flat heads and intake manifolds used. You will notice that early flat head fuel pump push rods had an umbrella on them to reduce oil splash. I think you will be fine with just removing the push rod from your 8BA and leave bushing alone. be sure to read Fordbarn discussions. Do not even think about cutting push rod off or leaving it in the engine making noise. Do not use silicon to seal it as silicon will eventually soften and come loose. You don't want any foreign matter getting in your oil p***age ways.
    Boden likes this.
  12. Why have a dummy mechanical pump?
    Electric fuel pumps are period correct and go back at least as far as the early postwar days of hot rodding.
    AutoPulse was an early Hot Rod favorite and has been around since at least 1949. I sold two N.O.S. a couple a few years ago.
    As were Stewart Warner
    Also Stewart Warners, these are not mine but I have a few of these for my projects.
    upload_2019-12-25_19-24-21.png upload_2019-12-25_19-25-21.png upload_2019-12-25_19-24-49.png
    kidcampbell71 and Desoto291Hemi like this.
  13. From my liberty The Birth Of Hot Rodding
    Note- AutoPulse fuel pump on the firewall
  14. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Get in touch with Vic Piano on the Ford Barn.
  15. 19Fordy
    19Fordy
    The old traditional pumps like Autopulse and the rest may look great but, the rubber parts
    dissolve with today's gas making them very unreliable. Plus, parts are not readily available.
    RMR&C and Texas Webb like this.
  16. Texas Webb
    Texas Webb
    Good point!
  17. clem
    clem
    Are we allowed to ask why you are using electric fuel pump over the original mechanical one ?
  18. clem
    clem
    Is it possible for you to give your reasoning for this ? - Thanks.
  19. Boden
    Boden
    The reason I am doing this is due to the fact that my fuel pump height above the guide is way different than any other intake. It is in between a 8ba and 59a rod. So I already cut my original rod to make it work and the tip cracked when I was removing it. Bought a new one and the tip is not removable from what I can see and it is not hollow. So I’m at a standstill. And I don’t see the problem with hiding a electric fuel pump and having it flow through the mechanical one.
    Desoto291Hemi likes this.
  20. I don't have a problem with it, I thought you were thinking electric fuel pumps aren't period correct.
    Plus the racer in me is always looking for was to take wight out of a car. Even if it is a few ounces.
    You, missed the point. I saying there is nothing wrong (period correctness) with an electric fuel pump and a block off plate on the fuel pump boss on traditional style car.
    However the AutoPluse parts are still available (Click Here) they are ungodly expensive, but 99% of people will never know if you put a modern electric fuel pump on the frame near the tank on a traditional style car.
    Here in New York state (where myself and Boden live) we can buy non ethanol 93 octane gas, at several brands of convert stores
    I have had to luck with mechanical fuel pumps, I am on my four in nine years on my 261 Chevy.
    I have used several good name brands, it's not the rubber parts that have failed it was the mechanical parts that failed, springs lever ect....
    Boden, Hnstray and Desoto291Hemi like this.
  21. Boden
    Boden
    Completely agree. I was just trying to find the cheapest way to do this since I don’t have much money. I like those auto pulse pumps. But the ones working are expansive and the cheap ones that aren’t working need the expensive parts. And plus I want to get this on the road sooner than later.
    Robert J. Palmer likes this.
  22. clem
    clem
    From previous posts on the HAMB, I have heard of several who have done this.
    Did I understand correctly that you are doing it just because your pushrod is the incorrect length ?
    If so could you make your own ?
    Boden likes this.
  23. BamaMav
    BamaMav
    from Berry, AL
    Reread post #5..........
  24. Boden
    Boden
    I was planning on doing that. But the tips of the rod are hardened. And when I removed my old ones they cracked. And the new ones are a different style. So I’m pretty much screwed with doing that.
  25. Boden
    Boden
    So what will happen if I run this without plugging the oil galley?
  26. adam401
    adam401
    If you want to run a mechanical pump just cut a rod and throw it in. Dont worry about hardened or not. When it fails just replace it. Everything doesnt have to be built for the end of the world especially something as easily accessible as that. Its easy to over think this stuff but usually good enough is good enough for non safety stuff. Get that thing running and drive it.
    I seriously seriously wouldn't hesitate to just cut a piece of hollow tube open on both ends and throw it in. They arent under alot of force. Youd have to put some real miles on before it ever wore down. I've owned a few old Fords. They are about one step up from a lawnmower in stock form. Move forward with confidence, it'll all be ok.
    Boden and clem like this.
  27. clem
    clem
  28. clem
    clem
    Best comment on the hamb today.............
    Boden likes this.
  29. Boden
    Boden
    Got it all figured out. Thanks a lot guys!
