Projects "No Quarter"- '27 T coupe project
Discussion in 'Traditional Hot Rods' started by SinisterCustom, Oct 22, 2008.
  1. CGkidd
    CGkidd
    Looks *****in Josh...
  2. falcongeorge
    falcongeorge
    from BC
    If thats the hieght the top of the shell has to sit at, I would consider trying to round the top corners more and put a little more crown in the top to better mimic the shape of the cowl. That will tend to pull the eye down the sides of the shell. Just a thought. I realize the shape/dimensions of the top rad tank are limiting what you can do here.
  3. Wardog
    Wardog
    If possible you should defiantly not put a 32 grille on this. Yours is heaps cooler.
    Sent from my DROID device using the TJJ mobile app
  4. dana barlow
    dana barlow
    from Miami Fla.
    Really need the rad tobe down about 3in. or more from the hight its at in photos,whatever you got to do,too make that happen is wroth it.
  5. falcongeorge
    falcongeorge
    from BC
    I'm really inclined to agree with Dana, and now is the time. Can you get the core shortened? Even if you can drop the grill shell 1.5" it will make a HUUUUGE difference. I honestly really like the shape of the existing nose, its good, in a sixties show-rod kinda way, the reason its not sitting right with you or us is because its too high, and the flat top exaggerates it, because the cowl line is slightly lower, and is curved across the top. I think a flat-topped grill shell can work here, but it HAS to be lower than the cowl. In my opinion, for the flat-topped grill shell to work, when you crouch down in front of the car and sight along the top outside edge of the grill shell just before it curves down, THAT spot has to be in a lower plane, or at least even with the corresponding area of the cowl. Right now, the centerline of the grill shell looks to be even with the centerline of the cowl, but the corners of the grill shell are HIGHER than the corresponding area on the cowl. See what I am saying? Not gonna work, IMHO.
  6. falcongeorge
    falcongeorge
    from BC
    Judging by the fan spacer, looks like you could move the rad back a bit, drop the bottom tank behind the crossmember, and extend the sides of the grill shell back a bit, with a notch at the bottom to clear the crossmember, Bobs yer uncle.
    IMO, you are REAL close to "totally *****in'" status, dont stop now.
  7. ChopTopJimmy
    ChopTopJimmy
    Josh, what's the brake master off of? Thanks, CTJ.
  8. falcongeorge
    falcongeorge
    from BC
    early sixties chevy PU.
  9. falcongeorge
    falcongeorge
    from BC
    If you do chopped '32 grill shell, this thing cries out for a horizontal bar grill insert. Check out the one Nostalgia59 made for his surf kart.
  10. SinisterCustom
    SinisterCustom
    Thanks for the opinions fellas.....
    Here's the deal....the current radiator cannot be moved, the bottom outlet and front crossmemeber have dictated where it goes. I've used this same radiator before, but what screwed me this time is the lower cowl of the T. I used same type radiator last time on my Model A. DOH......the only option would be to spend $600+ for a custom radiator with a lower profile, rounded top, etc.......
    I think a '32 shell will "almost" cure the issue. Of course I'll have to section it and will most likey take an inch or two out of the bottom center to "pinch" the bottom...
    And yeah....a horizontal tube grill would rule....
  11. falcongeorge
    falcongeorge
    from BC
    I agree, the '32 shell will help alot, as the curve on top will better mimic the curve of the cowl. The flat-top custom shell would only work visually if its quite a bit lower. That grill Nostalgia59 did is the dogs danglers, isnt it?
  12. SinisterCustom
    SinisterCustom
    Yeah man...I dig it.....it's rad.
    I'm too close to driving this thing to start tearing apart to re-engineer stuff like the radiator placement....or buy more part$$$....
    I'm really just a hack and there's enough ****ed up **** I'm hoping will work out...a grill shell and inch taller than the cowl is the least of my concerns....;)
    I'm a driveline, shifter linkage and fuel tank away from a test drive.....:D
  13. CGkidd
    CGkidd
    How long of a drive line do you need?
  14. SinisterCustom
    SinisterCustom
    @34"....thats from center of front joint (1310) to the flange on the rear end (which is an Explorer, so I gotta get the mating flange from Pull-A-Part)
  15. falcongeorge
    falcongeorge
    from BC
    COOL!!:D We want video!
  16. rob-redm
    rob-redm
    Looking good Josh ! That Pontiac wagon of mine is screaming for fun paint ! LOL
  17. CGkidd
    CGkidd
    Let me measure mine. I need to build a new one so we might be able to work something out.
  18. CGkidd
    CGkidd
    Just measured mine it is only 28. Sorry no go for you.
  19. langy
    langy
    Glad to see your back on this project, looking good !!!
  20. SinisterCustom
    SinisterCustom
    Shot final coat of primer on...
  21. 60galaxieJJ
    60galaxieJJ
    Here in Washington our weather dictates when we paint our cars lol
  22. Sage
    Sage
    Ooooo...Plaid/Gingham tire/wheel covers! Them's the 'cat's pajamas'!
    You hardly ever see those any more.
    Looking good Josh!
  23. rob-redm
    rob-redm
    Oh ya ! Josh looking killer brother !!!!
  24. CGkidd
    CGkidd
    Damn can't wait to see it finish up.
  25. falcongeorge
    falcongeorge
    from BC
    The newest thing in "wheelcovers". He's gonna duct tape those bad boys on there and go cruzin. Note that they ARE color-co-ordinated with the paint scheme...:eek:
  26. falcongeorge
    falcongeorge
    from BC
    By the way sinister, are my eyes playing tricks on me, or does that Superbee scoop bear the magic, mystical letters??
  27. Russian
    Russian
    i think the letters on the scoop are H E M I, but i can be wrong
    Sinister, i really like your T, so much details, very cool paint scheme
  28. CGkidd
    CGkidd
    Lets see a unveiled pic...
  29. SinisterCustom
    SinisterCustom
    Yeah man......trend-setter.........:D
    Yes....and no. The scoops were just ROBBED from a wrecked Hemi car....it's running a 440.
    This is all I've got right now...gonna throw a pinstripe around the beltline tomorrow and a design on the decklid and call the body done....she's just a "20 footer" anyway....haha
    brEad likes this.
