No Spark at the Plug...need help
Discussion in 'The Hokey Ass Message Board' started by Kage, Jul 17, 2012.
  1. Kage
    Kage
    from Delano, TN
    I just replaced the timing chain because it was worn and stretched. Below is a pic of the old timing chain. you can see how much slack was in it.
  2. squirrel
    do a compression test too :)
  3. Mr48chev
    BINGO WE HAVE A WINNER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    .025 is way too wide of gap on the points. They probably aren't closing all the way.
    You did set them on one of the high points of the distributor cam and not the flat?
    If things are working right you won't get a spark at the points when they open that is noticeable.
  4. MATACONCEPTS
    MATACONCEPTS
    Use your finger to block the #1 spark plug & crank the engine & look at the rotor to find TDC, you know how.
  5. Invalid BINGO...see post #29
  6. Mr48chev
    Ok, that will teach me to make sure I read through the whole thread. I've seen a lot of cars that didn't run because someone didn't set the points right though.
  7. Kage
    Kage
    from Delano, TN
    Felt like it wanted to crank a few mins ago...sputtered just a little..so close. Now I just need to play with the dizzy a little. Just have to find the sweet spot
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Do it right , find #1 on compression then line timing mark up on about the 6* mark. Then rotate dist CCW using a test light hooked to the movable point side of the dist.,wherever handy, with switch on turn dist till light comes on. Then wherever rotor is pointing will be #1 ,put #1 wire there and put the rest in order.Lots of times all I ever do to set timing is use the test light,no timing light needed unless you need to check for proper advance function.
  9. Kage
    Kage
    from Delano, TN
    She is trying to start but I think a bad fuel pump is holding me up. I will get that switched out in the next day or so
  10. squirrel
    did you check the compression yet?
  11. Kage
    Kage
    from Delano, TN
    I was going to do that this weekend. I have to go visit my buddy to borrow his compression tester
