Technical No spark
Discussion in 'The Hokey Ass Message Board' started by mopar57, Apr 18, 2017.
  1. mopar57
    mopar57
    I have a 57 plymouth belvedere. The motor is a stock 301 and I replaced the points,condenser,cap,rotor,wires,plugs, over the winter but haven't tried to start it untill now and I get no spark holding the spark plug in the wire about 1/4" from the exhaust manifold. I have 12v at the battery and I have 12v from battery negative terminal to the coil + terminal while cranking. I put the old coil back in and same thing. How do I check the coil to see if it's good. Thanks for the help.
  2. squirrel
    while holding the plug wire 1/4" from the engine like you are now, with the key on, touch a jumper wire from the coil (-) terminal, to ground. It should make a spark at the plug wire.
  3. Boyd Wylie
    Boyd Wylie
    check your point gap again. If the vehicle ran before you did the work,there is something you've overlooked.
  4. mopar57
    mopar57
    With the key on and using a jumper wire from ground to coil (-) no spark at the plug but I get sparks at the jumper wire when I touch the wire to the ground terminal battery or frame. I did recheck point gap and it's good.
  5. tb33anda3rd
    tb33anda3rd
    with the wire to the distributor from the negative terminal disconnected.:)
  6. boltupal
    boltupal
    from western ny
    You forgot to install the rotor.
    BJR likes this.
  7. ClayMart
    ClayMart
  8. bonzo-1
    bonzo-1
    double check that the points wire is not grounded. Disconnect wire from coil make sure the points are open. Put test light clamp on positive battery post and test the wire. If the light lights up, you are shorted to ground. If not rotate the engine so the points close, the light should then light up.
  9. Truck64
    Truck64
    from Ioway
    Run a point file or "sandpaper" through the point faces. They can get a layer of skunge on them quick if they sit for a while.
    Next put the original working condenser back in. The new manufacture condensers are junk and not to be trusted. Back in the day a lot of mechanics would leave the condenser alone when replacing points if it was otherwise running well.
  10. Blues4U
    Blues4U
    from So Cal
    "I get no spark holding the spark plug in the wire about 1/4" from the exhaust manifold. "
    If I'm reading that right, and you do not have the plug making contact with the manifold, or any other source of ground, then it will not spark, because the circuit is open. You have have to complete the circuit to ground for there to be a spark. Hold the plug against the manifold and try it again, watch for the spark across the plug terminals.
    rfraze likes this.
  11. Dan Timberlake
    Dan Timberlake
    Blues4U likes this.
  12. mopar57
    mopar57
    Ok when I get home from work I will try with the plug touching the manifold that makes sense. I do have the old condenser so I can try that as well. Thanks. Will let you guys know.
  13. rfraze
    rfraze
    Make sure that you have continuity between ground and where the negative wire to coil comes out of distributor when points are closed.
  14. gas & guns
    gas & guns
    After installing points, I always wipe em out with a dollar bill. The texture of the paper works good for removing any grunge or oil that may be on them from installing. It even works good for a motor that has sat for awhile and lost spark.
  15. mopar57
    mopar57
    So I checked continuity from the negative side of the coil and ground and had nothing. Cleaned the points and with sand cloth and re tested and found to have continuity now. Still no spark. Put in the old condenser and bam I have spark an car starts. I bought 2 condensers and both bad but the orig**** works. Any recommendations on where to get a reliable condenser.Thanks for the help.
    pat59 likes this.
  16. Blues4U
    Blues4U
    from So Cal
    This is an ongoing issue, others have had the same problem.
