Technical No Spark
Discussion in 'Traditional Hot Rods' started by 29ron, Mar 11, 2023.
  1. 29ron
    29ron
    Hi all,
    This is a new build using a Mallory magnetic distributor 5072001 with a PerTronix flame thrower 1.5 ohm coil. It is wired as the attached wire diagram. I have a 1ohm ballast resistor. I have no spark. I have tested the distributor as per the testing instructions and it’s working fine. Could it be that I need a Mallory 1.4 ohm coil. Any help is appreciated.
  2. leon bee
    leon bee
    I'm a points guy, but what happens when you byp*** that resistor?
  3. jaracer
    jaracer
    If you have it wired per the drawing, disconnect the green wire and see if you get a pulsing signal on a voltmeter when the distributor is turned. If you do, I'd be looking at the coil or the power supply to the coil.
    Tow Truck Tom likes this.
  4. FishFry
    FishFry
    Byp*** the Resistor.
    Also - not sure if this is the same with the Mallory, but Pertronix doesn't like some of the older RPM meters. If it turns out that this is a problem, you can get a inline filter from Cl***ic instruments.
    alanp561 and Tow Truck Tom like this.
  5. squirrel
    maybe you ought to find the wiring instructions for your distirbutor, not for an optical distributor?
    perhaps it's different. Since I think it requires an amplifier, while the Unilite has the amp built in.
  6. badshifter
    badshifter
    That distributor came with a “Power Cell” when new that is wired inline. Do you have that installed?
    Seems to be a problematic setup.
    https://www.jalopyjournal.com/forum...r-cell-failure-autopsy-what-to-do-now.993815/
  7. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    If your using 12 volts you shouldn't need a ballast resistor. That may be a low voltage situation.
  8. 29ron
    29ron
    I wanted to thank everyone for your help. I jumped out the ballast resistor and I got spark!!! It turns out the the PerTronix coil will only fire when the voltage is at 11.50V and greater. Anything less than and the coil would stop firing. I ordered the proper Mallory coil. This was a really good troubleshooting lesson. Thanks again!!!
    SS327, Blues4U and FishFry like this.
  9. Blues4U
    Blues4U
    from So Cal
    Thanks for coming back and letting us know what you found.
    SS327 and 29ron like this.
