Technical No Woo Hoo Moment, 9” Axle Splines
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Oct 11, 2025.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    For the first time I got myself up close to the rear end under the 32 project then this happened… upload_2025-10-11_7-41-53.jpeg
    While looking in the housing (no 3rd member installed yet, just axle’s) I seen how large the axle’s really are, 35 spline! All this time I thought this thing was only to be a cruiser. So why would have Carina purchased large axle’s years ago. That hunch led me to purchase a 31 spline 3rd member some time ago.
    Question is, can these axle’s be machined down enough (just where they insert 3rd member) that the 35’s disappear totally so 31 splines then can be machined onto them?
    Ok, I’m behind the chicken wire now. Let’s have it.
    SS327 and anothercarguy like this.
  2. patsurf
    patsurf
    will a caliper show that-?--we can worry about hardness later...
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If the net would supply me with people answers on axle diameters vs AI take over I’d be more able to answer that question.
    Just kicking ideas around. Probably cheaper to get replacement axle’s vs machine work and treating.
    Just Gary and anothercarguy like this.
  4. Jmountainjr
    Jmountainjr
    Sell the 35 spline axles (usually race stuff) to someone that can use them and buy 31 spline axles to go with the carrier that you already have.
  5. gimpyshotrods
    gimpyshotrods
    The minor diameter of a 35-spline axle is 1.4167".
    The major diameter of a 31-spline axle is 1.2500".
    So, yes.
    bchctybob, Bearcat_V8, SS327 and 4 others like this.
  6. DDDenny
    And if you have them machined make sure there is a "healthy" radius at the end of the cut.
  7. squirrel
    buy a 35 spline spool and be done with it :)
  8. Mike Lawless
    Mike Lawless
    Having done some axle re-splining back in the day, I'd have to suggest either finding a 35 spline diff (near impossible), or sell the 35s and buy 31s as jmountainjr suggested.
    I was never able to recut splines without annealing the steel first. High speed steel tooling wont cut it, carbide breaks. Then, if you don't get the heat treating just right after machining, the axles could either twist or snap.
    And for what it would cost to do that....just might exceed the cost of new axles.
    Kiwi 4d and banjeaux bob like this.
  9. gimpyshotrods
    gimpyshotrods
  10. saltflats
    saltflats
    from Missouri
    If you go shopping for 35 spline stuff you need to know the pressure angle of your axles.
  11. lake_harley
    lake_harley
    Maybe a call to Moser Engineering would answer the axle spline/re-splining questions?
    Lynn
    Zax likes this.
  12. Zax
    Zax
    Moser Engineering is great to deal with and will make custom shafts for you. You’d probably be better off selling the 35 spline shafts and buying a replacement set of 31 splines.
    Jeff Norwell likes this.
  13. silent rick
    silent rick
    a friend of mine had a Dana 60 with 9 inch bearing ends that used 35 spline axles, just another option
  14. deathrowdave
    deathrowdave
    from NKy
    35 spline is really common on a Dana 60
  15. gimpyshotrods
    gimpyshotrods
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Need 5 on 5 1/2”
  17. fastcar1953
    fastcar1953
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looked them up all ready.
  19. krylon32
    krylon32
    from Nebraska
    I have no idea of their quality but the cut to length 31 spline Big Bearing axles Speedway sells aren't that expensive. $226.00 Pr. Probably cheaper than having s local shop set up to cut yours? Plus the new axles come with new bearings.
    patsurf likes this.
  20. 38Chevy454
    38Chevy454
    Going from memory here, but I seem to recall that 33 spline is the largest that will fit a stock carrier. So even if you did cut down 35 spline to 31 spline, the modified axles won't work as they won't fit through the bearing.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sure they will. Just have to machine them down further toward the wheel flange. IMG_4775.jpeg
    bchctybob and SS327 like this.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    bchctybob, saltflats and Johnny Gee like this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Redbird Speed sell’s Quick Performance as well.
    bchctybob likes this.
  24. seb fontana
    seb fontana
    from ct
    Correction on 31 spline diameter OD is 1.330 +/-, 28 are 1.250 dia. DO NOT mess with the 35 spline axles. NOTHING BUT TROUBLE. The chance of success is minimal, cost will be staggering.
  25. silent rick
    silent rick
    sell the 35 spline axles to a rock crawler and get you a set of 31 spline
    Zax and seb fontana like this.
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reply #5 from @gimpyshotrods is the answer I was after. This does not mean I’m going the route of having axle turned down and resplined. Just that my question has been answered. In the mean time I have a few welds to get done (red arrows). Wrap up brake pedal switch. Fab up battery box/tray then paint mid section of the frame so cab can be dropped back into place. When that’s complete the bed will be removed. That’s when I’ll finally know what I’m going to do about my mistake. IMG_4772.jpeg
    chevy57dude, bchctybob and saltflats like this.
  27. big john d
    big john d
    from ma
    what brand are the axles what length are they?
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No idea. Project all ready had them before I got involved.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
  30. bchctybob
    bchctybob
    If Cook’s is still around, I’d give them a call. There isn’t much they haven’t done in the way of rear ends and axles and they are out your way unless they moved.
