Nobody has started one ...so ... what did you get done this weekend ??
Discussion in 'The Hokey Ass Message Board' started by Deuce Roadster, Jul 16, 2006.
  1. Deuce Roadster
    Deuce Roadster
    Almost 100 degrees here ... and humid ... so I have been staying in the house and the A/C a LOT ... :( But over the past week or so ... at night I work a little along ...
    It's a little too street rod for some ...
    That's OK too ...
    The wife and I like it ... :D
    Engine and 700R4 installed . Firewall painted and finished. Brake pedal back from Advance Plating and the coil springs back from the power coaters. Driveshaft in ... now to hang the lines ( trans, fuel and brake ) ... already bent and ready to re-install ...
    Painting the fuel tank now ... hope to put the 3W body on in a few days ... I sure wish it would cool down to 90 ... :rolleyes:
  2. brandon
    brandon
    spent most of yesterday and this morning lettering & striping a truck .....outside.....in the sun.....was in the lower 90's...thank god the truck was white....haha....hit the pool after that.....pretty much fried all of both days.......brandon
  3. kentucky
    kentucky
    Workede at the FD yesterfay, went to M*** and then cleaned house today. Hard core hot rodder here:D
    Deuce, that car is going to be awesome. What's wrong with having a car that is reliable, powerful and comfortable? It's cool in my book.
  4. Evilfordcoupe™
    Evilfordcoupe™
    I got fed up with it being so hot in the garage at home, so I cut a hole in the wall to install a 14,000BTU cooler.
  5. poncho62
    poncho62
    Just sat on my *** on the beach all weekend................Too damn hot.
  6. Goozgaz
    Goozgaz
    Nothing...too damn hot.
  7. Muttley
    Muttley
    I did nothing all weekend, even missed the HAMB meet yesterday, just way to hot out. :mad: :mad:
    The backyard today at 5:30 pm:
    The garage:
  8. attitudor
    attitudor
    from Finland
  9. thunderbirdesq
    thunderbirdesq
    I spent this morning extending the cab of the '34 and t******* the firewall to fit over the trans. It was hotter in the garage than outside so I pushed it out to do most of the welding. Needless to say, I now look like a freekin' lobster...
    I still need to extend the roof and hammer weld all the seams. They're just tacked together for now. I've been putting this off for weeks, but it turned out to be easier than I thought, so far. I think it's lookin pretty tuff!
    Here's a few mock-up pics...
  10. Old6rodder
    Old6rodder
    from SoCal
    Let's see,
    Saturday:
    Sweated.
    Finished some work for a customer.
    Sweated.
    Added a refurbished puke can and changed out all the rubber hoses to steel on El Toad.
    Sweated.
    Went to the Glendale "Cruise" show.
    Sweated.
    Sunday:
    Sweated.
    Spent the day working up at the float barn.
    Sweated.
    All in all, had fun, and lost a couple pounds.
  11. Gator
    Gator
    from Statham Ga
    Spent all day today trying to get the swarm of wasps living in the eave over my front porch evicted.
  12. Gumpa
    Gumpa
    I worked on the trike for my grandson and it is now all painted and put together. Still need to ***emble the steering and attach the fenders and chain. Then I can call him to get the kids to bring him out so I can get photos before it gets loaded up to go to his house. Gumpa
  13. david4991
    david4991
    from Louisiana
    found something to start off with. now i just have to go pull it
  14. Gumpa
    Gumpa
    More photos please. Gumpa
  15. Slammed88
    Slammed88
    from Canada
  16. I did honey doos all weekend long. Except for the hour and a half I spent in front of a friend's blast cabnet taking no stick primer off an old Ford wheel.
  17. It was about 90-100 here all weekend. But I still welded up a new rear cross member for the '54, and tore into the body rott that has eaten away the trunk floor/ rear inner fenders/ tail pan. No pics right now, but I'll get some up soon. Weekends are my only time to get some serious work done, so I can't let the temp. stop me.
  18. david4991
    david4991
    from Louisiana
  19. InDaShop
    InDaShop
    from Houston
    I literally should not have stepped foot in the garge this weekend.
    Cause now I've got a car that doesn't run and did. Several bolts that I now have to ez-out of the block which is still in the car. And the car is supposed to be somewhere tomorrow afternoon. That remains to be seen if that will happen. Just one of those weekends. I should have gotten drunk and ran my head through a brick wall would have been less painful.
  20. FiddyFour
    FiddyFour
    busted out the steering on the willys on saturday, installed the column and ran the u-joints and steering shafts down to the R/P. . . today i sweat my *** off for about 6 hours and got a little more of the floor/firewall replaced after choppin it out to make room for the 455 buick and T400. i was gettin pretty dehydrated i guess cause mama fiddy made me quit when she got home. said i was stagering and stammering/slurring my words and was giggling, so she asked how much beer i slurped down... i reminded her im outta beer so she said "you've had enough heat for one day. time to go in"
    :eek:
  21. terrarodder
    terrarodder
    from EASTERN PA
    Went to Syracuse, meet Denise and some other HAMRs, great weekend, the Terraplane purr like a kitten.
  22. Rich Rogers
    Rich Rogers
    only 94-96 degrees here today. Spent the day putting front and back gl*** in the 55 in the sun then decided what the hell its only 94 so finished sanding the roof and primed it.That was enough for me
  23. mazdaslam
    mazdaslam
    Dis-***embled the rear in my Merc for the SECOND time in 2 weeks to see why the NEW axle bearings and seals are leaking:mad: . Totally DESTROYED the bearings while removing them:D .Got new bearings and discovered that they have 2 seals,an inner and an outer:eek: .The other bearings had only one seal:confused: .So,with any luck,I have cured the leaking axles:) .
  24. Roothawg
    Roothawg
    It was 102-103 here all weekend at about 50% humidity. I labored to just stay in the shop.
  25. Cronk Design
    Cronk Design
    from Minnesota
    i got the jalopies body mostly together. i'd post pics but dont know how. got it sanded and painted satin almond. looking pretty hot. all i need to do now is rob the straight axle outta the f100 and whack 4inches outta it and weld it back to gether. should be fun.
    i'll post pics if someone PMs me how.
    ncg
  26. SlamCouver
    SlamCouver
    from Brazil, IL
    man i welded the door tops back on after the 6'' chop i just did to my 27,,,measured and cut new floorboards... grinded lots of welds.
    A good weekend
  27. TREE
    TREE
    from Piqua,OH
    100 degrees here, no breeze, too freakin hot in the garage. So, I did something that I usually do about every 2 years...gave the OUTSIDE of the garage a bath
  28. Nimrod
    Nimrod
    Went shoping for a new car.
  29. jakespeed63
    jakespeed63
    Spent all week at the new Miller Motorsports Park raceway, in Salt Lake City. 100 degree temps all week, must have drank 5 gallons of water every day. All this blood sweat and tears taking care of a customers $135k Porsche racecar, only to witness him spin out and get hit, head-on:eek: on the 2nd lap.
    ...oh well, got paid regaurdless, now I have the cash to get the Rocket Olds on the road!!:cool:
    JT
  30. screwtheman
    screwtheman
    Nimrod, is that a '67? I used to have one identical to it (well duh, it's stock) a few years back. Great car.
