Art & Inspiration non automotive parts you have used on your hot rod or custom
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jun 13, 2023.
  1. HOTRODPRIMER
    HOTRODPRIMER
    As the old adage goes necessity is the mother of invention.
    I'll kick it off with some interior pieces.
    When building the Ranch Wagon I needed sme green translucent material for the turn signal indicators, the original pieces were brittle and broken, I ended up using a green transparent lid from a plastic turkey container, a pair of scissors and creative t******* and that project was done.
    The high beam indicator was missing also, it needed to be red so a quick look around and another household item was used a Jif peanut ****er lid seemed to fit the bill. I use a leather hole punch to get the perfect fit.
    When we were installing the new recovered rear seat in the wagon, I was testing how well the seat would fold down and I was totally unaware the the material across the top of the seat was thicker than original, when I dropped it down the guiding pins punched two hole in the seat, I was sick and called it quits that day, the next morning I noticed my pal Dave was already in the shop and I asked him were we going to have to remove and recover the seat and his answer was no, "I have already fixed it."
    It turns out he loosed the trim around the seat and used to large soup s****s to cover te holes and to use as a guide to drop in on the pins, works great and honestly looks like something that might have been done at the factory.
    This is the back of the rear seat folded down.
    Lets see what odd and unusual things you have used in your builds. HRP
  2. Jokester
    Jokester
    But the necessity of invention is a mother!
    .bjb
    VANDENPLAS likes this.
  3. rustydusty
    rustydusty
    As an “avid” boater, I always have some marine hardware kicking around. On my T, I used stainless boat hinges and hasps to attach the turtle deck lid. The seats were replacement pads for restaurant chairs. The trim strip across the bottom of the deck is a piece of boat rub rail…
    RMcCulley, Stogy, Deuces and 8 others like this.
  4. Jokester
    Jokester
    Door handles from a janitor's closet.
    Denim upholstery.
    2x4 arm rests.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    7FD2D2C1-F215-415C-8478-FC0484DD77C0.jpeg A5BDFCBD-9B8B-435F-84EC-8F715EBA485F.jpeg C11B954C-31E2-4708-9D12-D28E0C647E26.jpeg Stainless exhaust tubing and Bed rails.
    Stogy, Okie Pete, dana barlow and 6 others like this.
  6. Budget36
    Budget36
    Cool topic.
    I won’t even make mention of road signs and chicken wire;)
    safetythird, Stogy, deadbeat and 2 others like this.
  7. DDDenny
    The shift boot mount in my roadster started out as a small cast aluminum cooking pot.
    safetythird, Stogy, gnichols and 11 others like this.
  8. rusty rocket
    rusty rocket
    The aluminum cover on the firewall was on my wife’s aunts barn that was going to get torn down it was a weather guard for the power line going into the building. 01F0B80A-B506-4BC6-B1AB-A8670A9FA528.jpeg
    Stogy, clem, caprockfabshop and 12 others like this.
  9. pirate
    pirate
    from Alabama
    Boat rub rail made of a hard rubber to cover the edge of 1 1/4” square steel tubing for a more finished look and to protect paint. IMG_1790.jpeg
    Stogy, Okie Pete, WC145 and 4 others like this.
  10. hrm2k
    hrm2k
    During my first attempt at 4 deuces, I used 4 hot water heater flus as velocity stacks.
    A friend works at a place that builds industrial parts washers. I think they had 25 of these flus from a customer run off. They were thrown away and we grabbed them. Next time you are near your water heater check your out. The flus connect to the chimney.
    Stogy, Okie Pete, WC145 and 3 others like this.
  11. In_The_Pink
    In_The_Pink
    I picked up two '50s era refrigerators a few weeks ago, intending (hoping?) to use the door and carc*** sheet metal for something on my '52 Nash Rambler-- firewall recess and/or patch, storage bin doors, interior panels... we'll see. The stamped pieces all have great curves/shapes and being from 1950, are all H.A.M.B.-era proper, too.
    GE fridge door:
    Hotpoint fridge door:
    Carc*** sides:
    I have a bunch of interesting br*** and aluminum pieces I've saved over the last few years, so they might be incorporated, too, at some point.
    Stogy, R A Wrench, brEad and 6 others like this.
  12. In the mid to late 60s in Sportsman/Modified racing they were commonly used as hoods.
    This era-
    Stogy, orbitup, deadbeat and 9 others like this.
  13. In_The_Pink
    In_The_Pink
    Shift boot by...Oatey? :D
  14. Lloyd's paint & glass
    Couldn't lay down the cash at the moment for a sheet of aluminum diamond plate for my bed, so it has a sheet of 1/2" pressure treated plywood in it :D:p painted black and put back :cool: 20230613_111116.jpg
    Stogy, bschwoeble, Okie Pete and 7 others like this.
  15. Mr48chev
    All I have to say is that you guys are good, not one thing that doesn't look like it doesn't belong there down though post 14.
    Stogy likes this.
  16. Building your own steering column and need a collar, or modifying one and don't want to h***le with the die-cast ones most have?
    This is a drawing table lamp, but you'll find similar in table lamps. Steel, trim to size.
    This one is 5" across the big end, 2" at the small end. $25-35 for the whole lamp...
    safetythird, Stogy, Okie Pete and 5 others like this.
  17. pirate
    pirate
    from Alabama
    I posted this before in another tread but it fits pretty good here.
    When I was building my tube frame sports car there was no room for a trunk, glove compartment or any dry storage. When I entered the USMC in 1965 one of the first things they gave me was an ammunition box to store rifle cleaning (solvent, oil, patches, etc.) and for whatever reason I kept it over the years. I cut off the bail handle cleaned it up and painted it and mounted it to the frame next to the fuel cell. So I now have a waterproof compartment to store registration, insurance papers, sungl***es or whatever I want to keep dry or out of sight for security. [​IMG]
  18. Lone Star Mopar
    Lone Star Mopar
    Not me, but I remember a Hamber welding an old steel Wok for a diff cover in the trunk of his Hot Rod years ago.
    Stogy, Okie Pete, Ned Ludd and 2 others like this.
  19. BamaMav
    BamaMav
    from Berry, AL
    air deflector 1.jpg air deflector 2.jpg air deflector 3.jpg underhood gauges.jpg My pa in law had a fridge go bad, so he put it in the s**** pile. It was one of those double door ones with the stainless doors. I snagged the doors and made an air deflector to keep all the air going through the radiator instead of over it. Also made a gauge pod for a couple of gauges under the hood.
    Stogy, brEad, Cooder2 and 10 others like this.
  20. Dad's idea to use an old canteen as a upside down so it could be drained as a coolant catch can on my model A stock car build.
    upload_2023-6-13_19-31-1.png upload_2023-6-13_19-31-49.png upload_2023-6-13_19-32-14.png upload_2023-6-13_19-32-39.png
  21. bowie
    bowie
    Back in the 70’s, when I was cobbling on my “A” coupe; I found a 1950’s counter edge fit the inside edge of my doors. I thought it gave a nice smooth look to them. Still there 50 years later : 99214EED-63B1-462E-916E-58289A29C56C.jpeg 45C324B6-A761-43F1-8C07-D3A6DF99ACD4.jpeg
    Stogy, VANDENPLAS, Okie Pete and 5 others like this.
  22. Dave G in Gansevoort
    from Upstate NY
    Sorry no pictures, it was 51 years ago. Used an inexpensive stamped wheelbarrow to make a firewall for my CJ5 that I stuffed a 327 into. Got the idea from Hot Rod Magazine. I think that it sold new for around $15. It took the most time cutting the rolled edge off.
    Stogy, VANDENPLAS and Okie Pete like this.
  23. 51 mercules
    51 mercules
    Drum b*** pedal for a gas pedal.
    Stogy, steveareno, R A Wrench and 7 others like this.
  24. 4speed411
    4speed411
    Art deco clamp on bed lamps converted to Kool taillights PXL_20230521_143950175.jpg
    disturbio, Stogy, steveareno and 12 others like this.
  25. deathrowdave
    deathrowdave
    from NKy
    My Moon Style tank is 2 aluminum frying pans with sheet aluminum rolled between the 2 . Hillbilly Delux
    Stogy, brEad, VANDENPLAS and 2 others like this.
  26. Joe Blow
    Joe Blow
    Fender amp handle for door handle, aircraft tail wheel quadrant lock for door lock and 60's leather bike seat bag for glove box.
    Electrical junction box for under-dash switch box.
    Vintage aircraft seat belts for fuel tank straps.
    40's Pullman train clothes hook for coat hook.
    ......and 30's Acme bottle opener for emergencies.
  27. hotrodjack33
    hotrodjack33
    My old Sedan Delivery...
    SPREADER BAR; Stainless handicap bathroom grab bar (Home Depot)
    HEADLIGHT BAR; Threaded rod covered with chrome sink supply line (Ace Hrdware)
    TURN SIGNALS; 1950s Schwinn bike fender lights
    HOOD ORNAMENT; Novelty pen, chrome cat
    AIR CLEANER COVER; 1938 Ford hubcap
    TAILIGHT HOUSINGS; Stock taillights mounted inside cut down desk lamps (Lowes) [​IMG]
    HEADER PANEL made from section of vinyl rain gutter (Lowes) [​IMG]
  28. wraymen
    wraymen
    A co worker used bed frames to stiffen up his Trans Am that he cut the roof off of. On a bumpy road it sounded like being on the first floor of a sleazy rent by the hour motel.
    Stogy, VANDENPLAS, Okie Pete and 2 others like this.
  29. topher5150
    topher5150
    I found this square tubing at Home Depot works good for making brackets IMG_20210612_172753014_HDR.jpg
