non roller cam oil
Discussion in 'The Hokey Ass Message Board' started by Bill Rinaldi, Apr 25, 2012.
  1. Bill Rinaldi
    Bill Rinaldi
    I'm running a fairly new 350 Chev. I have been adding zinc additive to my Pennnzoil at oil change time because I'm running a flat tappet hydraulic cam and lifters, not roller. Other than amzoil zrod oil, what other oil is non roller cam friendly? BILL RINALDI
  2. Hnstray
    Hnstray
    from Quincy, IL
    Brad Penn Racing oil
    Ray
  3. brandon
    brandon
    X2 on the brad penn....here schaffers is pretty good as well
  4. scoop56
    scoop56
    from Canada
    25 w 50 Penzoil Highest zinc content on the market.
    It is racing oil and if you read the
    label on back, it is not recommended
    for "regular" engine use. Newer cars
    don't like zinc.
  5. smittythejunkman
    smittythejunkman
    I use brad penn racing oil in my non roller engines
  6. MUNDSTER
    MUNDSTER
    Chevron Delo 10-40 Diesel truck oil plus Lucas break-in additive or GM equivalent. Flat tappet survival kit.
  7. greg32
    greg32
    from Indiana
    Bill, most any racing oil, we run valvoline 20/50, but others are fine. Brad Penn is the old kendall green oil. They bought the refinery from kendall, the name was sold to somebody else. Penn uses the same old excellent base stock. Joe Gibbs products are superb, contact joe rhynne, he sells it locally. None are cheap. Pep boys here quit selling racing oil.I can get you a decent price on valvoline products, cousin owns an oil change.
  8. bobss396
    bobss396
    I use Kendall exclusively in any performance engine that I've ever had. The 20W-50 in street cars, straight 50 in the stock cars.
    Bob
  9. DirtyJoe
    DirtyJoe
    I use Kendall oil too.
  10. xmb63
    xmb63
    from pittsburgh
    Is 20w50 to thick for a daily driver? That's the only wt. I can find in the valvoline racing oil locally.
  11. k5hart
    k5hart
    Valvoline VR1 is what I've been running. I also ran 20w50 in a couple cars all the time and never had problems.
  12. Gman0046
    Gman0046
    Valvoline VR-1 racing oil. Has the highest levels of Zinc and Phosphorous.
  13. Rusty O'Toole
    Rusty O'Toole
    What about Shell Rotella 15w40?
  14. 283john
    283john
    I heard Rotella has scaled back their zinc and other slick-um content.
  15. bobss396
    bobss396
    Above 40* you should be ok... any colder it may be good in a garage a bit lower. I always used 10W-40 in the winter, got caught with my pants down too often with the 20W-50 when it dropped unexpectedly.
    Bob
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    NAPA will order any weight valvoline vr1 racing oil you want...just ask
    dave
  17. unkledaddy
    unkledaddy
    Try a search on here, this subject's been worn out.
    Brad Penn with 1/2 bottle of zinc additive.
  18. brian55lvr
    brian55lvr
    from ma
  19. mustang6147
    mustang6147
    from Kent, Ohio
    If your buyin your Pennzoil from an engine builder, it has the highest level a zink out there. If your getting it from a parts store shelf, then no.... Pennzoil has a specific line of oils only available to better engine builders. In Cleveland 1 distributer is Gellner Engineering.
    I use Castrol HD 30 in my fat tappet race engines. Never have any significant wear after the season.... I use castrol in eveerything I own that isnt New. New stuff ( alluminum engine) get Mobile 1 or Dexos.
  20. jack orchard
    jack orchard
  21. Carnuba
    Carnuba
    20/50 Valvoline racing oil (VR-1). It's usually the easiest one to find at the chain stores like Pep Boys and Autozone
  22. George
    George
    CJ is scaled back. I've seen oil marked SM/CJ so apparently to be SM compliant SJ must not have any higher levels of zinc than SM. "Accel" brand 10W-40 SF oil is available once again @ Wal-Mart for easy availability on the road.
  23. Weasel
    Weasel
