Non-streaking glass cleaner
Discussion in 'The Hokey Ass Message Board' started by 5window, Jan 13, 2009.
  1. gonzo87107
    gonzo87107
    X2!! It foams up on the gl*** and doesn't dribble down into your door or paint.
  2. mj40's
    mj40's
    I also use Sprayway and have for a couple years. Also good for plastics and no ammonia. I get it at Costco and in a blue can.
  3. Reverand Greg
    Reverand Greg
    33.33% Alcohol,33.33%white vinegar,33.33%water,then use news print to clean
  4. retromotors
    retromotors
    Uh ...... isn't that removing the patina?:eek:
  5. Kustom7777
    Kustom7777
    from Austin, TX
    i have an auto detailing business,,i like the invisible gl*** too,,,,,,,
    i use two towels, a microfiber (wash it first though) and a terry cloth,,,,,spray cleaner on the window, clean the gl*** with the microfiber, and use the terry to polish,,,,,im fussy,,,,,and this works the best for me...
    also make sure the windows are cool to the touch (VERY important,,,,hard to get a streak free window when the gl*** is hot or even warm)..
  6. TooMany2count
    TooMany2count
    from Cahokia,IL
    I use all their products w/great results.......joe
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Sprayaway does it for me
  8. Red Ryder
    Red Ryder
    Clearly, there is no doubt about it. The best stuff for avoiding streaks on gl*** (and the cheapest) is to use good old vinegar and water mix. Wipe off with newsprint ONLY for flawless clarity. Much better and cheaper than Store Bought stuff, in my opinion. Or... go buy the stuff off the shelf and take potluck! The proof is when you are staring into the sun!
  9. timmy t
    timmy t
    Used sprayway with good results too.
  10. mow too much
    mow too much
    Sprayway, its the best I have used, I've used it for 38 years.
  11. autobodyed
    autobodyed
    from shelton ct
    i don't do windows!
  12. You guys must be rich, what with having gl*** in your window frames and all... :mad:
  13. JustBryan
    JustBryan
    from NE Ohio
    Chromedaddyo gl*** treatment !!
  14. FCCOOL
    FCCOOL
    i am a detailer at a mercedes benz dealer, we use hospital sheet rag, synthetic rags, t shirt, towl etc just dont seem to get quick strek free results, towel leaves lines and lint and t shirt just spreads the window cleaner around, we ran out of hospital sheet rags once and tried etherything we could find but nothing worked, also at another place i worked we used this blue cloth from a hand towel thingo wich wasnt to bad, we are using meguiars concentrated gl*** cleaner, sometimes when its mixed to rich it hazes after a week.
    if you really dont want streaks use a gl*** polish, you wipe it on let it dry and wipe it off, also if you want a shine on old gl*** give it a good rub with some felt and cerium oxide mixed with water, even better buff the gl*** by machine with a hard foam pad making sure every thing is clean, any grit will leaves nasty rings, even better again use a proper felt gl*** buffing pad. disadvantage is its messy and neads alot of cleaning up afterwards.
  15. loveoftiki
    loveoftiki
    from Livonia,Mi
    3M gl*** cleaner with a 3M micro fiber towell should do the trick
  16. zman
    zman
    from Garner, NC
    Yep White vinegar and water... and newspaper...
  17. mbmopar
    mbmopar
    from Canada
    that or i've used windsheild washer fluid in an old windex bottle....anything works well if used ( obviously ) out of direct sunlight.
    Derek
  18. publicenemy1925
    publicenemy1925
    from OKC, OK
    x3!
  19. gashog
    gashog
    Use 000 steel wool on DRY gl***. Get's off bugs, tar, dirt and leaves no streaks.
  20. Muttley
    Muttley
    Sprayway is the best stuff ever, it also works great on chrome.
  21. I cant believe no one has said good old methylated spirits! A spray bottle, use straight in a cool climate or dilute with water in warmer areas. I use the hospital sheet to Cleon (I have dozens of them), news paper works well too.
    You do get metho in the US?
    Hell we even used the good ol' metho sprayed onto our feet to help harden them up in the Army. Its good stuff and if your hard up a little orange juice and metho and drink......
    Doc.
  22. Flop
    Flop
    all that ****s nasty for you to work with methyl alcohol glycol polypropylnol
    all **** we used in water to make it not freeze for doing windows in winter
  23. plym_46
    plym_46
    from central NY
    The solution isn't the problem the process is. I was dealership detailer for 2 years, I made my own mix of dish detergent, vinegar and water. But I used to use newspaper but eith the change over to soy based ink, that tends to now put more stuff on than it takes off. If it really bad, I use a small windhsield squegee like the ones at the gas station with the nylon scrub deal over the rubber foam core. Spray agitate and squegee off. Repspray and using a clean blue detailers cloth, or micro fiber cloth reclean the gl*** a section at a time, then immediately go over the area with a clean dry detailers cloth. Then turn the cloth ove and polish with the new dry side. for the ext window or section use the first dry rag and the new wet one, and get a new dry one for the polishing.
    Have also found that a light coating of final detailing spray applied to the inside and polished off after the gl*** is clean, keeps the schmutz off between cleanings.
    And just think all that chemical **** out g***ing form you new cars plastic, carpets and adhesives is not only going onto the gl***, its going in you lungs.......
  24. custom_line
    custom_line
    from Las Vegas
    pledge multi surface does wonders
  25. I think on newer cars, the 100% plastic interior sort of sweats out some slimy plasticizer **** which winds up condensing on the insides of the windows. I think that slimy stuff is what's so hard to clean off of the gl***, since most of the gl*** cleaners just sort of smear it around instead of dissolving it. So using something that's pretty rough like newspaper or heavy duty rough paper wipers works good to sort of s****e that **** off.
    I wonder if some sort of oily solvent like mineral spirits would work to get most of the slime from the plastic off first, and then when that's dry, follow up with normal gl*** cleaner. When I installed a windshield last time into a frame, there was some greasy smeary stuff on the gl*** that didn't seem to want to come off in windex, so I used mineral spirits. Then I followed up with Windex, and it finally came clean.
  26. bumpercarkid
    bumpercarkid
    from Orion, MI
    I find newspaper works great as well. But I was given some Snap-on brand gl*** cleaner and it works great.
  27. Stevie Nash
    Stevie Nash
    I bought some cheap "leaves no streaks" gl*** cleaner at Menards, thinking in the back of my mind that it would be worthless. Turned out it's the best gl*** cleaner I have ever used. It's called Sparkle, it comes in a purple bottle, AND it's ammonia free.
  28. Blue50F-1
    Blue50F-1
    Ditto the sparkle stuff, it works wonders, though it isn't cheap.
    I detailed my way through college for a small hi end dealer. He was the pickiest man I've ever known. But it led me to this: Dawn, Vinegar, & Water will clean anything. Then WAX the windows! Streak free EVERY SINGLE TIME! And it helps them stay clean too!
  29. What did you wax the windows with? Like Turtle Wax or something?
  30. Blue50F-1
    Blue50F-1
    Started off with Eagle's Shake n' Shine, but have used other automotive wax including Turtle Wax's Minute Wax (less work, less lasting finish, but great if you're about to have a car looked at by a client).
