Projects Nontraditional Truck Build (1936 chev truck)
Discussion in 'The Hokey Ass Message Board' started by STEELJUNKY, Aug 25, 2008.
  1. I picked this truck up off ebay for 800.00 and two years later it was on the salt. more pics to follow.
  2. Removed engine, trans, and leaf springs to figure ride height, had to cut pies from frame to lower without a big Z in front and rear.
  3. I stole this from 9 inch, is this it finished?
    CBB
  4. I machined the original 6 lug chev spindels to fit a ford 4 inch drop I beam.
  5. Yes, thats it but I have more build pics.
  6. Before 2 inch chop, removed 6 inches from rear of the bed.
  7. 2 inch chop.
  8. Metal worked most of the body, pics at the down and dirty show.
      34.5 KB
      36.8 KB
  9. 30roadster
    30roadster
  10. I had to seal the body with flat green paint so I could drive on the salt, pictures taken by akreone (thanks John)
  11. Thanks for the support!
  12. akreone
    akreone
    from SLC 801
    You have to see and hear this in person to really appreciate the craftsmanship. Every detail is well thought out and well executed. Troy does amazing work and is a hell of nice guy to boot. Can't wait to see it all finished up!
  13. timmy25252
    timmy25252
    Looks Great... I just got my 36 on the road last week....
  14. MCDANIEL1234
    MCDANIEL1234
    looks good to me keep it up
  15. Terraizer
    Terraizer
    Looks great what size tires are on it?
  16. 1951bomber
    1951bomber
    from atwater Ca
    one word 'aawweessoommee'
  17. steeljunkieII
    steeljunkieII
    Good job troy now show me how to do picks
  18. unibody
    unibody
    Nice truck, that thing just has the look.
  19. front wheels are off 41 chev car tires 600-16 rears off 53 chev truck 700-15 tires.
  20. 1rustyhighcab
    1rustyhighcab
    do you have any shots of the front suspension? where does your spring attach to?
  21. eharnden
    eharnden
    Good work on the truck, this is by far the best looking 1936 chevy truck since i have been looking for ideas for mine, what setup do you have in the rear of the truck, what yaer is the ford front axle, and is the cab channeled at all, i want to find a way to get mine low without having to chop the thing into pieces to do it
  22. Thanks! the cab sits on its stock cab mounts just added rubber, the I-beam is a super bell with 4 inch drop if you zoom in on this pic you can see I welded a piece of steel under my wishbones, my leaf sits under the stock radiator mount that I modified.
  23. I will take detailed pics of my suspension, I used wishbones on the rear but welded tube at the end and pressed in bushings. Rear is a triangulated 4 link with adjustable ride height. The way the cab sits it did not need to be chopped I just wanted to try a mild chop and a little pier pressure helped (thanks James)
  24. breeder
    breeder
    nontrad? looks alot more trad then most! killer build!!!!!!!!!
  25. 49ratfink
    49ratfink
    where did you find the tiny model A to carry around on your bed?
  26. Big T
    Big T
    from Florida
    Cool build and good-looking ride there fella.
  27. eharnden
    eharnden
    what did you use for the seats and thanks for the info
  28. I made a steel frame and used plywood and foam.
