I know this belongs in the classifeds but,, I need a section from a Ford K member that takes the front wishbone pivot ball. needs to fit the '36 ball. like TODAY. Paul
I used a section out of a 36-39 2-ton truck crossmember for front and rear. They use the same size ball as car. Another thing you can do is sandwich a plate with a U-slot in it between two wishbone ball caps. Is this for your rear radius rods? I am in the middle of that right now. Good luck. Neal
[ QUOTE ] Is this for your rear radius rods? [/ QUOTE ] yes, I split the front and am using the ball on the rear. thanks for the tip. Paul
why this place absolutely ROCKS! what was that, two and a half hours? thanks old beet and Marshal! Paul
