Hot Rods NOS SBC Mickey Thompson aluminum block
Discussion in 'The Hokey Ass Message Board' started by 54popular, Nov 7, 2014.
  1. what a nice collection of rare bits. keep the pics coming. thanks.
    Al.
    Deuces and volvobrynk like this.
  2. Shaggy
    Shaggy
    from Sultan, WA
    I know the m/t catolog i have from '63 offers a 4" stroke crank for a SBC, but i cant see how it'd fit since 383 chevys have issues with cam clearance. Will it fit in one of those blocks, i'm wondering? or were they only sold to guys planning OHC motors?
    Deuces likes this.
  3. 54sled
    54sled
    Now for the best question?how much did you give up for that?
    Deuces likes this.
  4. 54popular
    54popular
    I can't give away all my secrets, 54sled. :p
    Sent from my XT1080 using H.A.M.B. mobile app
    Deuces and 54sled like this.
  5. 54popular
    54popular
    Here comes some more...
    Deuces likes this.
  6. 54popular
    54popular
    Ellis Manifold "Synchro-Gizz" for tuning vacuum signals on multi-carb setups with small throat 1 & 2 barrel carbs (Stromberg, etc). Never seen another besides this one.
  7. 54popular
    54popular
    "Sandcast" Holley Dominator carb as used by early NASCAR and Pro Stock teams. This is the first type of Dominator that Holley was experimenting with before they ever went into m*** production. This is the standard 4500 model with the same bolt pattern as modern Dominators. There was also a 4600 model that was even larger for use in IR (Individual Runner) applications: flowed over 2000 cfm and had a larger bolt pattern. Note the squirter is actually cast into the main body. Restrictors have been installed underneath the ****erflies to reduce cfm. Boosters are actually installed by hand and peened in place.
    Deuces, odcics2, Hombre and 2 others like this.
  8. 54popular
    54popular
    NOS Saaty "Meteor Fuel Injector". A cool looking early attempt at a carb boasting gains in fuel economy. This carb is in the original box and still has the original paperwork and stickers too. Wish I had 5 more to stick on an Edelbrock 6x2 crossram.
    GuyW, Deuces, Hombre and 2 others like this.
  9. 54popular
    54popular
    NOS Mickey Thompson magnesium quick-change trans-axle case as used in his Pinto funny car.
    Deuces, Hombre, kidcampbell71 and 3 others like this.
  10. sdluck
    sdluck
    WoW what ****.
  11. 54popular
    54popular
    Early Edmunds 312 Ford Y-Block 3x2 setup with Stromberg 97's. I've seen several 2x4s but hardly ever come across a 3x2.
    Deuces, ls1yj, Hombre and 2 others like this.
  12. 54popular
    54popular
    2 different SB Chevy tri-drive timing cover setups. One is by Automotive Racing Components, the other is a one-off by Richard Lyeth who used to road race a Ferrari 375 MM Pinin Farina Spyder with a SB Chevy. The motor used a tri-drive just like this as well as a custom blower that looked similar to a modern Camden with side-draft carbs.
  13. 54popular
    54popular
    And my last bit of unobtanium **** for the evening, an NOS Briar MacKay experimental "Floatless Weber" intake. Looks like an early Crower injector base with a hollow fuel cooler in the middle and custom risers added on top which mimic a Weber 48 IDA carb. Basically its like having 4 carbs connected by 2 common shafts with ****erflies just like any other injector. The fuel p***ages, fuel/idle mixture screws, jets/jet holders, etc would all be just like a Weber 48 IDA carb. However, there would be no float bowl so it would be a constant flow just like an injector. I guess you could say it's a hybrid between an injector and a carburetor. Either way, I still love it!
    Baumi, Deuces, Hombre and 3 others like this.
  14. sdluck
    sdluck
    Sweet
    Deuces likes this.
  15. falcongeorge
    falcongeorge
    from BC
    Holy ****!!
  16. 3wLarry
    3wLarry
    from Owasso, Ok
    all of these aluminum bits are well and good...but do you have any NOS 1932 Ford parts?
    :p
    Deuces, kiwijeff and kidcampbell71 like this.
  17. volvobrynk
    volvobrynk
    from Denmark
    This is so F-ing awesome, that it makes me hold my breath til I becomes dizzy. While reading with open mouth.
    Bosch injection with the Diesel style pumpe is freaking awesome! So much I wish to know more. And steal a copy of your pictures :eek: :cool:
    That cross ram with the IR and the Alfa style flanges that needs rubber insolatores, that spaces the carbs outwards, and adapts to Weber/dellorto bolt pattern. Cool beond belive! :cool:
    Those unfinished hemi heads, are they missing spark plug holes, or em I getting blind. If thats the case, I blame, because I feel like molesting my self when seeing this awesome collection! :eek: :cool:
    And then Dugans, so awesome! Lost for words.
    Did you give up your first born, your man parts or something ever worth to become the owner of that lot!!
    Deuces, kiwijeff and loudbang like this.
  18. Offset
    Offset
    from Canada
    Lost for words.
    Deuces likes this.
  19. 54popular
    54popular
    The spark plug holes actually haven't been drilled yet. The Hemi heads are partially machined. As for the timed Bosch injection, I actually have a second set up I am building thats for a small block Chevy. Same concept but uses a modified Hilborn injection manifold. This is an old photo I found online of a complete set up to give you an idea of what it looks like.
    Deuces, volvobrynk and kidcampbell71 like this.
  20. volvobrynk
    volvobrynk
    from Denmark
    I know of simalar set-up on Mercedes (6cyl) and BMW (4cyl). And then as a Diesel set up. But it looks SO awesome in the Valley of a V8.
    I most confess that when I here 350 SBC I loose a little of my drive, but 265/283/301/307/327
    Makes me all giddy, and warm inside.
    What block/size are you working on?
    But that set-up makes my pants fit all funny. Regartless of engine its sits on.
    Those dugan heads, what induction set-up are they meant for?
    Deuces likes this.
  21. 54popular
    54popular
    The Duggan heads have a Weber 48 IDA bolt pattern. The heads can either have Weber carbs bolted directly to them or use Duggan made stack injectors or 4 barrel intake.
    Deuces likes this.
  22. volvobrynk
    volvobrynk
    from Denmark
    Is there anything to gain in bolting it carbs directly to the head? Excepept for short runners, that interms gives a better low end power band, but can it be to short?
    Deuces likes this.
  23. 54popular
    54popular
    The runner length on the heads isn't really much different than if the carbs were bolted to a standard Weber intake because they stick up so tall.
    Deuces likes this.
  24. bowie
    bowie
    54popular: Any more of your groovy dream parts to share? I'd love to see what your wheel selection looks like.
  25. I'm not a jealous person but.... I think this thread has changed me!
    Dustin
  26. 54popular
    54popular
    Yes Bowie, there are more parts still to come. Been busy at work so haven't had much time over the past few days to photograph them. Hopefully in the next day or 2 I should get some free time to dig more stuff out.
    Deuces and bowie like this.
  27. ExpressionsDesignCo.
    from Kokomo, IN
  28. JC Sparks
    JC Sparks
    from Ohio
    The coolest thing you got is that Danekas super blower. JC
    Deuces and kidcampbell71 like this.
  29. YENKO ZL-1 ENGINE COPO CAN-AM BLOCK ALUMINUM
    DON YENKO CAST THESE AT GM TONAWANDA PLANT IN NEW YORK WITH THE ENGINEERING STAFF AS A JOINT PROJECT IN 1974
    One on ebay now
    Price:
    US $23,140.00
    Deuces and jckc like this.
  30. 54popular
    54popular
    Yeah, that Danekas super blower sure is a pig alright. Despite it being all magnesium, it still felt like my arms were going to fall off trying to heft it onto the shelf.
    Deuces likes this.
