Not another 36 ford coupe!! Not another build!!
Discussion in 'The Hokey Ass Message Board' started by jamesville, Nov 9, 2010.
  1. JAWS
    JAWS
    Oh, ok yeah that makes more sense...sorry for the rabbit trail.
    I'll go back and sit down so others can have a turn...
  2. jamesville
    jamesville
    from Copehagen
    hi JJ
    no i am running 48's for the 1st and 3rd and the primary carb is a 97.
    do you still think its 2-4.
  3. JAWS
    JAWS
  4. jamesville
    jamesville
    from Copehagen
    Well she fired up without too much trouble, the only reason it didn't fire on the first start is because i forgot to put the choke on!!
    <iframe ***le="YouTube video player" cl***="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/uudC1HVX968?rel=0" frameborder="0"></iframe>
  5. jamesville
    jamesville
    from Copehagen
    And here we are testing the transmission, all seems to be fine.
    <iframe ***le="YouTube video player" cl***="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/AmZMp1aqnng?rel=0" frameborder="0"></iframe>
  6. farmer12
    farmer12
    Great to see all is working! Thank you for posting the vids. Keep up the good work!!!
  7. Dooley
    Dooley
    from Buffalo NY
    ahhh the sound of a sbc the universal language....how many times over the years have a group of guys huddled around a new motor waiting for the fist time it fires. Esp the guy who built/installed it, it is a special feeling.
    great job
  8. hasty
    hasty
    Congratulations. And very nice work.
  9. JAWS
    JAWS
    Very nice.....sounds good, great work.
    Valve adjustment?
  10. Angry Frenchman
    Angry Frenchman
    looks like you guys are haveing fun, great job!
  11. Enbloc
    Enbloc
    from London, UK
    Well done. Sounding good.
  12. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Damn!!! So happy for ya Jamesville! You guys really hustle and knock it right out. I'm feeling like a slacker. I've been polishing a Dizzy for two nights now.
  13. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Wow, this is turning out to be a REALLY nice car! Keep it up!
  14. nitrohonkey
    nitrohonkey
    You own my favorite car ever...I could even look past the engine problem in the beginning if I had my name on the paper-work. Besides, 2bbl 265's used to blow the doors off of full-house flat-heads.
    Looks great!
  15. BrerHair
    BrerHair
    Congrats!! Very cool.
  16. rattlesnakehoey
    rattlesnakehoey
    from Australia
    Great thread, thumbs up from Downunder
  17. lowcoe
    lowcoe
    Jamesville, Thanks for this thread... I learned lots.... I just have a couple questions.... Why did you have to put an adapter on the torque tube? Whats the benifit of lincoln gears? Why not run a modern ******? Have a few more but maybe I should PM... I'm doing something simmilar and Im new at all of this.. Any threads that you found helpful on your journey would also be apreciated whether it be clutch, brakes or whatever... thanks...
  18. jamesville
    jamesville
    from Copehagen
    hi Lowcoe,
    so to answer your questions,
    the adapter is on the back of the engine in front of the ****** not the torque tube. its a stock set up from the ****** backwards.
    the benifit of lincoln gears is when you have more power, as 1st and 2nd gears are a little longer. but really i just did it because it is cool, not very smart financial.
    i did not run a modern ****** because in denmark i am not allowed to (i should not even be changing the engine). and also i would then want to change everything else behind the ******, rear end etc and that would of been too expensive. and last because i am build a late 50's style hot rod.
    to many good threads to list, ask me question and i can tell you what i have learnt.
  19. lowcoe
    lowcoe
    Had to think about that answer for about a week... I guess you misunderstood. I wasnt talking about the engine adapter i was talking about the picture on page 7 where you said
    "The torque tube has had the new six spine adapter welded up for the new pinion, its the last big job i have to do is re-build the rear end."
    Thats where I lost you. Your changing the rear end right? this has nothing to do with adapting the 283 to the stock transmission.
  20. jamesville
    jamesville
    from Copehagen
    oh ok, no i am putting in 3:54 gears replacing the original 4:11.
    but the new pinion (the thing sticking out of the rearend) has six teeth but the original had 10. so you need to cut and weld a new one on the end of the torque tube.
  21. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Truth. I ended up just taking a '39 rear and replacing the '35 that I had in it. That way there was no cutting or welding...proving once again that there are many ways to skin a cat.
  22. jamesville
    jamesville
    from Copehagen
    So i have taken a break from the car for a while, it all gets a bit much sometimes. you just need a rest from all the troubles and i had a big one a ahead of me. it was the body!!!!!
    the biggest problem is the floor, in mexico when they were replacing it they decided it was too much trouble to remove the original one. so they just put one on top of it. so i had to cut through layers of **** work, i never understand that when doing a job why would you not just do it RIGHT!!
  23. wrenchin hobo
    wrenchin hobo
    from Houston,TX
    Very impressive. This build is very inspiring.
  24. 58Lincoln
    58Lincoln
    Floors look real good.
    It's NO FUN correcting inferior work. I probably drilled out 300 pop rivets and removed 4 or 5 aluminum panels and 4 or 5 Florida license plates attached to the top of my original floors.
  25. tinmann
    tinmann
    Excellent build..... making a silk purse from a sow's ear.... as my mother used to say. Fantastic skills you have there. I still don't understand how you have a workshop inside of a parking garage.
  26. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Geez dude, that body being back on is a really great step forward. I swear I'm going to **** myself if I see you driving this before I finish mine haha!!! happy for ya though and the floors looks really great.
  27. jamesville
    jamesville
    from Copehagen
    Why are you puzzled that my workshop is in a parking garage???
    Well it's right downtown, in the middle of the city. Does it make sense now?
    That gives me an idea for a thread 'workshops in strange places'
  28. jamesville
    jamesville
    from Copehagen
    10:30.................
    3:30.................
  29. jamesville
    jamesville
    from Copehagen
    So to me this is when the fun starts, no more cleaning rusty or greasy parts. the summer is just around the corner so the race is on to see if i can get it driving for at least one event.
    I had to bend the spindle steering arms this week which was very scary and i have this bad feeling, i have no idea if i did it correctly but its done now, its too late. it seems like it works which is a good thing.
    collecting my frame was fun in my new truck, i had to drive right across town with it sticking 10 ft in the air, watching out for low bridges.
  30. Finnrodder
    Finnrodder
    from Finland
    Looks great,you have done nice work.That knucklehead on the background looks good too
