Hot Rods Not comfortable with this.
Discussion in 'The Hokey Ass Message Board' started by frdsuperduty, Jun 22, 2017.
  1. frdsuperduty
    frdsuperduty
    from Lewes De
    My 1927 model T sedan has Lincoln drum brakes on the front and 11" drums on the rear.It is a lite weight car{fenderless}For normal driving the brakes work pretty well.But when I try to lock them up as in Skid,it wont.Its seems to stop quickly and does not feel like glazed lining .It stops.But Im not use to a car that wont skid the tires.I put the car up on jack stands and spun the front wheels.As soon as I hit the pedal the lock up.You cant move them by hand.With the car in gear and spinning the rear tires,hit the brake they lock up.This is with no momentum.The master cylinder is new and the rod has the correct stroke I believe.Is it possible that a lite weight car with big brakes and large tires just does not need to skid to stop quickly.I have a hard time believing that but .......Im lost.
    40Vert likes this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    IMHO, I would rather stop than skid. HRP
    oj, upspirate, Hnstray and 4 others like this.
  3. New cars don't skid either? Anti-lock brakes I believe they are called.
    flatout51, Blue One and Max Gearhead like this.
  4. frdsuperduty
    frdsuperduty
    from Lewes De
    I new someone would anti lock me
    cactus1 likes this.
  5. What are you using for a master cylinder?
    Charlie Stephens
  6. frdsuperduty
    frdsuperduty
    from Lewes De
    Early mustang drum disc.
  7. You may need to downsize master cylinder bore by 1/8" for more hydraulic advantage. It will cause a little bit longer stroke at the pedal, but with a set pressure at the pedal, you will have more pressure at the shoes because of the smaller master cylinder bore.
    Just an idea.
    Atwater Mike likes this.
  8. frdsuperduty
    frdsuperduty
    from Lewes De
    What will thee additional pressure do?Are you thinking the lining is not expanding enough or not holding?
  9. Cosmo49
    Cosmo49
    Yet you have drum/drums? Seer ****er shorts with paisley shirt, it won't work.
  10. frdsuperduty
    frdsuperduty
    from Lewes De
    Not according to the supplier.Why do you say that?
  11. gimpyshotrods
    gimpyshotrods
    Is it taking too long to stop? Why do you want the brakes to lock?
    When the brakes are locked you don't have control over the ch***is, you have left it up to the vicissitudes of the Laws of Physics. You might not like that outcome.
    When the brakes are working properly, you will be at a full stop, before any of them lock up.
    upspirate, Just Gary, Hnstray and 3 others like this.
  12. On an early car without anti-lock brakes I expect to be able to lock my brakes. Not locking them is something I do to decrease stopping distance, sort of self applied anti-lock brakes.
    Charlie Stephens
  13. gimpyshotrods
    gimpyshotrods
    Are you capable of controlling a two wheel skid? How about a four wheel skid?
    If skidding is so helpful, why is every single vehicle sold in the US, in recent history, equipped with a device specifically designed to prevent it? I wonder if automobile accident fatality rates dropping have anything to do with that....
    If only we knew an engineer we could ask....
  14. The master cylinder application appears to be 1" bore. What do you think Gimpsy? Asking seriously, not other.
  15. gimpyshotrods
    gimpyshotrods
    I still want to know if the vehicle is taking too long to stop. From the OP's comments: "Its seems to stop quickly...", it would seem that it does not, so I am not sure what we are discussing here.
    If I build a car, and it stops quickly, without locking up any wheels (aka: losing control of the vehicle), I call those properly functioning brakes.
    Hnstray, 49ratfink and slowmotion like this.
  16. Of course I am not capable of controlling a skid, that is the reason I said I don't lock them. Who said skidding is helpful? If you got that from my post you are reading something into it that wasn't intended.
    Charlie Stephens
  17. hotroddon
    hotroddon
    A disc / drum master will have a built in residual pressure valve on the rear only. So it will cause the rears to come on before the fronts as the fronts can easily **** in air by not having the RPV in the system. But most of your stopping power is in the front, so that is the Opposite of what you want.
    fol and Cosmo49 like this.
  18. 302GMC
    302GMC
    from Idaho
    You don't give the wheel cylinder bore sizes. That would really help.
  19. slowmotion
    slowmotion
    Not skidding, ain't a problem, not stopping is a problem.
    Hnstray, gimpyshotrods and mike 51 like this.
  20. frdsuperduty
    frdsuperduty
    from Lewes De
    I'm uncomfortable because after 50 or so years of driving a lot of old cars it just feels odd.
  21. frdsuperduty
    frdsuperduty
    from Lewes De
    1 inch
  22. mike 51
    mike 51
    from norcal
    I agree...skidding ain't stopping,just wasting rubber and maybe endangering someone's health.
    upspirate and Hnstray like this.
  23. gimpyshotrods
    gimpyshotrods
    First car with really good brakes, in 50-years, might feel odd, but that does not mean that there is a problem with those particular brakes.
    Hnstray and Tman like this.
  24. frdsuperduty
    frdsuperduty
    from Lewes De
    Maybe your on to something here.
    fol likes this.
  25. frdsuperduty
    frdsuperduty
    from Lewes De
    Could be.That was my speculation.
  26. FWIW, I went to a site and found that as an example, 1955 Ford car has 1" master and wheel cylinder bores. It's a heavier car too.
    What kind of brake pedal is in the car? Just for info.
    Food for thought.
  27. frdsuperduty
    frdsuperduty
    from Lewes De
    Don't know them.
  28. tfeverfred
    tfeverfred
    In post #21, you said 1".
  29. frdsuperduty
    frdsuperduty
    from Lewes De
    That's the master cylinder bore size.Not the wheel cylinder bore size.
  30. Do you understand "pedal ratio"? for non-power applications it should be about 7to1 power set-ups more like 4to1.
