Not O/T Late auto tranny question 93 Chevy truck
Discussion in 'The Hokey Ass Message Board' started by Fat ASS Whitewalls, Sep 6, 2007.
  1. I'm building a 55 Chevy truck for a guy. He gave me a ****** out of a 93 Chevy truck, 1/2 ton. It's all electronic, speedo, everything. What is it? Thanks
  2. squirrel
    probably a 4L60E.
    does it look like a 700R4 but has more wiring connectors? if so that's what it is.
    if it was from a bigger truck it could be a 4L80E, then it would look like a stretched TH400
  3. spudz
    spudz
    an electronic 700r4... has one big plug on the right side???
  4. spudz
    spudz
    actually I am confused....only I call em that.... they are technicly 4L60Es... which is really just an electronic 700r4. Just an early 4L60E...1993 might of been the first year??
  5. Yes. Is it a good ****** to use? Can I use it without the computer? Will an aftermarket speedo work with it? Thanks
  6. famous59
    famous59
    from dallas, tx
    not sure if you can use it wiithout the computer, per the overdrive. Check with painless wiring
  7. 56pu
    56pu
    from Sarver,PA
  8. it' an early 4L60E, i would trade it for a (older) 700r4 unless you want to run a computer.
  9. The engine is a GM crate 350, with a carb, and electronic ignition.
  10. knotheads
    knotheads
    if it were me i would trade it for the good old time proven 350 turbo trans ,or a 400 turbo .
  11. 56pu
    56pu
    from Sarver,PA
    I personally would talk the guy into getting a 700r4 for a driver, 4l60s are great when working right but very expensive to rebuild, I have a 4l60 in my 56 dodge, it cost me $1400 just for a basic rebuild.....But if he is just going to use it as a weekend warrior then the th400 is ideal....imho
    Harmon
  12. $1400 for a rebuild, damn you could buy a whole running truck for that. And probably rebuild a 56-64 Hydramatic for that money, too.
    A late 700R4 is a pretty tough trans to break unless you set out to do it intentionally, it might be a little easier to use one of those instead.
  13. I think I have him talked into a 350, or 400 turbo.
  14. Shifty Shifterton
    Shifty Shifterton
    Stick with the overdrive, he'll thank you for it later. But go to the non-electronic 700r4 or 2004r. Both very good transmissions with a few upgrades. Good luck
  15. spudz
    spudz
    200r4s ****....
  16. 40Standard
    40Standard
    from Indy
    I 2nd that
