Technical (Not) rocking and rolling
Discussion in 'The Hokey Ass Message Board' started by ERguitar, Oct 5, 2019.
  1. ERguitar
    ERguitar
    I bought some "patina" vaguely shaped like 1949 f3 yesterday. Since non of the wheel s wanted to roll it took a tractor to move it on to my trailer, lifting/dragging.
    So my question is any suggestion on freeing rims up? I'm not opposed to any methods no matter how destructive as long as I can roll when I'm done.
  2. tb33anda3rd
    tb33anda3rd
    back off the brake adjustment.
    lothiandon1940 likes this.
  3. Brakes are most likely locked on.
    Remove the wheels
    And get the drums off !
    Back off the adjusters
    Remove the wheel bearings in the front and pry pull wiggle
    Sometimes a few strategically placed hammer blows pops the drum off easily.
  4. bill gruendeman
    bill gruendeman
    B6421DFC-E6CE-43F3-89CD-2AC08E492D7A.png 904251E5-5EFC-4C68-A629-077F3568F80C.png I have the same problem with my international truck that sat On the ground for 25 years. I cut the brake drums with a cutoff wheel and removed the hub to remove the center then re***emble the hub, it worked for me
    Bandit Billy and 49ratfink like this.
  5. ERguitar
    ERguitar
    Bill, I think I'm in the same situation. Ill probably end up going with a similar solution. Thanks for the suggestion.
  6. bill gruendeman
    bill gruendeman
    your welcome. The drum cut pretty fast . luckily I only had one to do, the rest I could pound free.
  7. CJS1958
    CJS1958
    You could cut the adjusters out with a torch from the backside
  8. ERguitar
    ERguitar
    For future searchers...I followed Bill's advice on the rear brakes. I tried a different approach for the fronts.
    Cut two slots and drive wedges in, seemed to work.
    Now how do I fix the misspelling of the ***le?....
    Edit. Fixed it.
    vtx1800 likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    In years past everyone use to say HEAT & a Big Friggin' Hammer. HRP
  10. deathrowdave
    deathrowdave
    from NKy
    I have always had good luck , drilling 4 equally spaced holes against the hub where the drum rests . Lube the hell out of it , use a chisel and cut the anchor pins off . In a bit of BFH work , they usually pop free . I’m in need of 2 F2 or larger backing plates if you locate any while parts hunting also .
  11. tubman
    tubman
    On the threads you started, there is a "dropdown" called "Thread Tools" on the top of the first page towards the right side. You can use that to fix the ***le of the thread.
  12. ERguitar
    ERguitar
    Thanks tubman.
  13. ERguitar
    ERguitar
    Started a "conversation" deathrowdave, not sure if that's how I'm supposed to pm you.
  14. deathrowdave
    deathrowdave
    from NKy
    I got it . Thanks again and be safe
