Technical Not sure what happened
Discussion in 'The Hokey Ass Message Board' started by iron dave, Feb 24, 2021.
  1. iron dave
    iron dave
    Painting today not my best thing and this .Rattle can just trying to learn
    Sent from my SM-G960U using The H.A.M.B. mobile app
  2. 49ratfink
    49ratfink
    hard to tell.. either dirt on the part or maybe the paint was applied too thick.
    loudbang and grumpy65 like this.
  3. grumpy65
    grumpy65
    My best bet would be moisture or other contaminant under the paint. Surface prep and cleanliness is the key to a good result. 90% prep / 10% paint technique. Paint also looks way too thick. Build up with thin coats rather than trying to do it in one go.
    @Lloyd's paint & gl*** , help a guy out here. This **** is your bag.
  4. Black_Sheep
    Black_Sheep
    Bright silver spray paint does crazy stuff, my guess is it was applied too heavy and without adequate time between coats.
    49ratfink and VANDENPLAS like this.
  5. Hey my pager just went off! I'm here! Looks a lot like the substrate under the paint is the problem to me. Like really thick primer?
    loudbang, VANDENPLAS and grumpy65 like this.
  6. Sporty45
    Sporty45
    How many coats and how long between each coat? Looks very heavy to me or not enough time between coats
  7. 1ton
    1ton
    One thing you have going for you is that it cant get much worse that that. Thin coats on a properly prepped surface will get you going.
  8. Sporty45
    Sporty45
    Black Sheep beat me to it! :D
    49ratfink, Black_Sheep and VANDENPLAS like this.
  9. squirrel
    Chrome shop screwed up?
    49ratfink, VANDENPLAS and iron dave like this.
  10. chevy57dude
    chevy57dude
    Last time I didn't let the primer completely dry hard the same thing happened to me.
  11. wheeldog57
    wheeldog57
    Take a couple deep breaths, sand all that off. While doing so you can think about all the above comments ^^^^.
    Seriously though, many light coats with the spray can. Let each coat sit until it is almost dry then hit it lightly again. Yes, it ****s waiting but the results will be worth it. Good luck bro.
    loudbang, grifcarnut and VANDENPLAS like this.
  12. grumpy65
    grumpy65
    Ahhh, that's why you get paid the big bucks Jim. It's a bumper.
    It does indeed look like silver paint over chrome. Not going to happen without surface prep..........o_O
    Unique Rustorations likes this.
  13. oldiron 440
    oldiron 440
    From my model car days;
    Flat paint over gloss paint will make splits like that.
  14. squirrel
    I think there are lots of combinations of **X paint over YYY paint that will do that.
    49ratfink likes this.
  15. I'm guessing heavy primer to fill in rust pits, and it wasn't dry. So i second your statement. Lacquer over enamel will pull it off like paint stripper.
    chevy57dude likes this.
  16. rusty valley
    rusty valley
    looks like it lifted old paint from chemical reaction. was it bare steel, then prime an paint?
