Not sure what wire harness to get.
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, May 24, 2009.
  1. Well the one from the car shop is close to the original one 6 volt.
  2. metal man
    metal man
    I am a big fan of American Autowire. These come with all the switches and are very easy to install . Best of all , you wire from the component to the fuse panel , not starting with a big wad of wires already attached to the panel .Makes it much easier all the way through the process and of course all the wire is marked and pre-sorted,organized. Before you buy , look at what all actually comes with the kit ! Another thing nice about AW is the connections to the fuse panel are quick disconnect with a small screwdriver. Very good customer service too.
  3. dragass
    dragass
    I just finished wiring my 55 Ford Fairlane with a Rebel Wire 9+3 kit. Highly recommended for the easy to follow instructions and the exellent tech support.
  4. tbcworks.com
    tbcworks.com
    Kwik Wire!! Pretty nice set-up.
  5. hugh m
    hugh m
    from ct.
    Have had real good luck with Ron Francis, and would reccomend him, but next time I'll probably go with an alliance member, just because.
  6. ol'chevy
    ol'chevy
    I have used 2 Its a snap and one ezwire, All with the micro use box. No problems from either. The snaps are both 24 circuit and the ez is a 12. One of the snaps is in my truck.
  7. JimA
    JimA
    Rebel Wire is a VERY nice kit!
  8. I for sure want a kit with a small box.
  9. Ghost28
    Ghost28
    Rod and custom the one with the red 32 and pure steel a coupe on the cover. Just did an article on the 12 circuit ez wire being installed. kinda interesting...ghost
  10. adamabomb76
    adamabomb76
    from York, Pa
    Rebel. I like them. Their wires are marked more closely than the streetrod counterpart. The gage of wire is very nice. The instructions are good if you have touched a car before, but if you are a gimp you better find a friend that has. If I had to buy another harness to wire a car again....I'd still buy a Rebel harness.
  11. I like the quick disconnect feature from american autowire.
  12. Deuce Roadster
    Deuce Roadster
    I am currently installing a American Autowire 15 in my 32 Ford 3W coupe. It is small enough to fit on a firewall of a 32 coupe ... with Vintage Air A/C and a glove box. Pretty simple to install and all the wires are well marked.
    Not knocking any one else's KITS ...
    Rebel Wire is American made and Glenn33 seems to be a stand up type of vendor ( and a HAMBer ) but I went to the NSRA Street REod Nationals in Louisville 2008 and looked at every wiring vendor there. Ron Francis to EZ wire ... and everyone in between.
    I liked the American Autowire the best.
  13. Well I went to americans website and Im just confused. Im not sure what one to get. Are they all made for gm?
  14. glenn33
    glenn33
    from Browns, IL
    If you're confused, give them a call. If you're still confused after that, give me a call :)
  15. Spike!
    Spike!
    Hey Man...I work at Ron Francis and I'm a HAMBer...I highly doubt that you're lining pockets..just paying bills! You can go cheaper price but it won't match our quality.
    Spike
  16. Well thaks for all the kind words guys. Im still going to proceed in doing my home work on this. Thanks
  17. nico32
    nico32
    from fdl, wi
    I agree :)
  18. 49 Custom
    49 Custom
    I bought American Autowire's Highway 22 kit for my '49 Ford. Rebel was a close second choice for me. It came down to the cosmetics of the fuse panel. The kit was broken down into steps that were individually packaged and separately documented. The wires are all individually marked every few inches and almost every imaginable terminal and connector was there, as well. It also came with a generic ignition switch, headlight switch, and dimmer. Bottom line: the car was up and running after a long weekend!
