Not your Granmaaaw's BANGER
Discussion in 'The Hokey Ass Message Board' started by Bluto, Sep 11, 2007.
  1. Bluto
    Bluto
    Here's my new old banger block :) :) :) :)
    Anybody know what this is ?
  2. Dakota
    Dakota
    from Beulah, ND
    Chevy or olds? or is it something way off the beaten path? its OHC. and Cast Iron?
  3. Bluto
    Bluto
    OK I got the crank out ...... does that help?
    The block and crank are all drilled but there's no place for an oil pump :)
    Maybe a shot of the front will help.
    What do you think that big chunk-0-iron at the top of the block for?
    motoklas likes this.
  4. gahi
    gahi
    from Moab, UT
    gravity feed oil system?
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Do you think that may be a GAZ50 or later Russian Jeep engine? They were based on the B Block Ford banger and later converted to OHV before transfer of all tooling etc. to the Chi-Coms.
    Back in the late 60s a bunch of new Russian Jeep B engines and parts were imported by devious means to the US and sold by several old Ford outlets.
    Sadly, after some months of investigation in the late 80s the Chi-Coms informed us that the GAZ series engine tooling they had received from the Russians was destroyed when the updates were made to the Chinese military vehicles. So, the wuestions is, can you trust the Chi-Coms...I think not.
  6. Bluto
    Bluto
    Did those jeep blocks have bronze main caps and a magneto on the side?
  7. Stovebolt
    Stovebolt
    Ok, I won't tell ;)
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    I do not know the internal construction of the GAZ other than the project started out as a stock 34 counterbalanced crank B block.
  9. Henry Floored
    Henry Floored
    Dang! Ford tractor or industrial???
  10. Bruce Lancaster
    Bruce Lancaster
    Open jackets with plates look ooold...maincaps and crank look modern. If it's Blutos, it's something pretty esoteric. Dang...looks like half a Wills StClaire...
  11. Henry Floored
    Henry Floored
    The interesting part to me is those look like insert bearings. The original arhitecture looks like Model A three main bearing with rear thrust. With the extra two webs being thinner than the "original" three. Hence my inclination is a beefed A or B design for tractor or military use.
    I think that extra boss is to mount a water pump and I of course that bottom end is fully pressurized for oil. Water jacket plate looks to be an additional measure to increase cooling since it looks from the picture that the barrels are surrounded by a first layer water jacket. The plate I guess encloses another water layer/chamber increasing cooling capacity.
  12. Henry Floored
    Henry Floored
    No valves or cam but obviously a place where they one were. I think the theory of this being basic Ford architecture is on target with some OHC type valve arrangement.
  13. Henry Floored
    Henry Floored
    The bore centers kinda look "A" as well. Guess I'm gonna feel like a real dope when you tell us what this really is. :- )
  14. Bruce Lancaster
    Bruce Lancaster
    Obviously based on something with low cam, but obviously cast with much of that architecture deleted...Open jackets suggest less sophisticated foundry...
    Frontenac.
  15. TV
    TV
    I think I'd have to guess it's an early Hal block, as Bluto seems to find all these neat parts.--TV
  16. Bluto
    Bluto
    HAL's are aluminum ...........
  17. Bobby Green
    Bobby Green
    I'm gonna guess a Hercules buda engine. Guys would use the 5 main cranks in model a's and b's.
  18. revkev6
    revkev6
    from ma
    miller maybe??
  19. CoalTownKid
    CoalTownKid
    Very interesting!!! No casting marks or stampings anywhere??
  20. metalshapes
    metalshapes
  21. Bruce Lancaster
    Bruce Lancaster
    Staring, staring...lower flange is starting to look like A-B with side timing cover cast in...and look at the undrilled UPPER casting pad on the rear...that is suspiciously Fordlike...wish I were at home with an engine block to compare. Bunch of upper surface holes seem to match up to A-B too...
    Dang, I'm starting to think this might well be designed to live where there once was a B block...
  22. Larry T
    Larry T
  23. it's a JIM.. says so right on the side. duh
  24. Bluto
    Bluto
    I wrote my name on the side so the guy in the scrap yard I got it from didn't sell it to someone else
    Man I rode my bicycle home as fast as I could and got the truck.
    This things heavy!
  25. HotrodVon
    HotrodVon
    Could it be a CockShutt 30 ?
    Keven
  26. clues.... it's heavy... and you ride a bicycle...
    nope, no idea :D
  27. revkev6
    revkev6
    from ma
    after looking around it seems that hal made steel blocks as well. hal indy/big birtha blocks were steel, seemingly copies of fords.
    possible?? haven't seen anything that includes the mount on the side that this block has though.....
  28. Bruce Lancaster
    Bruce Lancaster
    OK...found better photos to scrutinize. I see complete match (as much as a match can be made without dimensions) of the bolt pattern and other holes around cylinder tops to a Model B...bolts on right of engine shown, around where valves would be if flathead, I can't see. Maybe not drilled. Pan area seems to correspond...and lookit the water inlet pad, as well as that upper rear pad. Gotta be a based on bolt patterns and dimensions of '28-34 Ford.
  29. Bruce Lancaster
    Bruce Lancaster
    Without normal cam or any holes for pump/ignition, the side mount pad would be needed to carry a side drive off of the front cover for ignition, probably water pump, and oil pump would have to be either on side or off of front too...
