Notched?
Discussion in 'The Hokey Ass Message Board' started by travisty, Jul 13, 2010.
  1. travisty
    travisty
    from just moved
    What does it mean when someone says the cars been notched?
    Thanks
  2. boones27t
    boones27t
    from redding ca
    it means that the frame in the rear above the axle has been raised or notched to allow the rear axle to travel further which will allow it to set lower.
  3. hvychvy
    hvychvy
    I'm guessing your talking about c-notched,which is where the frame ,on a lowered car, is cut to allow suspension travel clearance for the rearend of the car.
  4. Hightone111
    Hightone111
    It's a mark you carve into the front fender everytime you hit an old lady.
  5. need louvers ?
    need louvers ?
    Naw... for those you just use a spray can and stencil...
  6. Mr48chev
    Travisty, It's as the guys said, increasing the axle to frame clearance so the car or truck can be lower without the frame hitting the axle. We used to just put a half circle cut from 3-1/2 or 4 inch tube in the frame and then reinforce the frame to give a bit more clearance but now they use the big notches to get enough clearance for the rig to lay out on the ground when you let the air out of the bags.
  7. fab32
    fab32
    I thought you couldn't place the notch unless you confirmed a "kill":eek:
    Frank
  8. Hightone111
    Hightone111
    Oops, thats correct. I'm thinkin of "botched"
  9. travisty
    travisty
    from just moved
    Thanks guy, that makes sense...
