Notching Wishbones?
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Apr 15, 2009.
  1. so we're installing the front end on smiley's A coupe and for whatever reason, the tie rod is hitting the wishbones. we have a SB 4" dropped axle and cast 4" dropped arms. should clear right... not.
    we cant put the tie rod on top because of the front motor mount and we cant bend the arms down so we figger its time to "notch" or "clearance" the wishbones to clear.
    JustinB gave one suggestion on how to go at it, just curious what if any other solutions there might be floating around in HAMB land.
    thanks.
  2. have you tired deep drop steering arms? should put the tie rod below the wishbone.
    FYI , the steering arms are forged ,so you can tweek them a bit
  3. HotRod33
    HotRod33
    post a picture so we can see your problem...
  4. its real simple.
    there's not enough drop in the 4" dropped steering arms, so the tie rod is up against the bottom of the wishbones before the tie rod ends are all the way up in the steering arms. i need to clearance the bottom of the 'bones so that i can install the tie rod...
    so i'm looking for ideas on accomplishing that.
    unless there's some other good idea that i didn't have.
  5. fab32
    fab32
    Pay attention. It's already been posted that they are forged so you can drop them a bit further by heating an bending them.
    Frank
  6. pay attention.
    its already been posted that they are CAST.
    and they are the deep drop units.
    thanks.
  7. thunderbirdesq
    thunderbirdesq
    You could also source a pair of Willys tie rod ends. They have an inch or so of drop built into them. However, they're not cheap if you can find them. Just a thought...
    How much room do you have to gain? If it's not much, you might try gently heating that area of the bone and adjusting it slightly with a hammer. If it's any more than a small fraction of an inch, you're probably better off cutting an area out and moving it up. Remember to make it large enough, the tie rod travels fore and aft slightly as it moves side to side.
  8. yeah, i looked into that, but then we have to re-do the tie-rod and then we get into scrubline issues...
    we probably need at least 1/2" clearance. JustinB suggested notching and plating, but i'm trying to avoid that at any cost.
    i found out where the arms came from, so i think i'm gonna see if they'll swap 'em for some forged deals.
  9. You always go with hairpins and go through the middle. I have also seen old wishbones that have been modified with a hole in them and then reinforced.Would look better than notching the bone.
  10. hammeredabone
    hammeredabone
    Hey Alteredpilot, If I am reading your post correctly, you have a superbell 4" drop axle with superbell 4" dropped arms. Won't work with your setup, so much for the obvious.
    I have a pair of magnum forged deep drop arms that clear the wishbone with a magnum 5" drop. I can measure the drop when I get home if you want.
  11. I thought this was a fairly innovative solution----Brian
  12. its a superbell axle and some other arms. i'd appreciate the measurements...
    brianangus...
    quit showing off...:D
  13. I didn't do this. I found it while prowling the internet, and was so blown away by the "different factor" that I copied it and saved it. I am sure it probably works great, its just that I would never have thought of it!!!
  14. i'm curious , who makes cast bolt on steering arms?
  15. hammeredabone
    hammeredabone
  16. TexasHardcore
    TexasHardcore
    from Austin-ish
    You could always bend the tie rod at the ends, similar to the shape of the dropped axle. Doesn't affect anything other than clearance.
  17. concreteman
    concreteman
    Nice job I notched mine for the clearance needed
  18. 28hiboy
    28hiboy
    from Milton, Fl
    Seen spacers under the steering arms under an F100 with a dropped axle that spaced the tie rods about 1in lower. Not what I like, but---- Also seen 46-48 wishbones used, the ones with the bend in them, just turn over, or swap sides until ya find the right combo. And yes, you might have to pie cut the bones to do this. Thats two ideas. Good luck
  19. 26T
    26T
    from Denver
    I had the same problem. If you use 46-48 wishbones they have a jog in the front that gives you a half inch or so. It worked for me. I looked at notched bones too but I needed too much thats why I switched bones.
  20. HotRodFreak
    HotRodFreak
    5" dropped arms work for me with split bones and 4" drop axle.
  21. 63Compact
    63Compact
  22. 31HotRodLincoln
    31HotRodLincoln
    I pie-cut & welded my A-bones on a 4" dropped axle and bent/lowered 40's spindle arms, clearance is about 3/4" from the radius.
  23. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
  24. Those steering arms you've got are designed for hairpins, which is why they dont work. I had the same problem. Ditched the arms and replaced them with straight plate arms from Speedway, but mounted so the tie rod is underneath the arms but clears the top of the 'bones. Worked for me, but if you dont have the clearance on top of the bones you'll have no option but to go with the Magnum 5" arms.
  25. yeah...
    kinda tripped me out too.
    i even called the place they came from and asked and they said they are cast...
  26. careyohio
    careyohio
    Please tell us where the cast bolt on steering arms came from.
  27. The only issue with that is two fold. First many of the tire rods aren't thick enough wall to remain strong enough with bends and second it makes setting toe a real pain in the arse.
  28. lil32b
    lil32b
    from Belgium
    so, will the steering arms for a 5" dropped axle work on a 4" dropped with unsplit wishbones on original 32 chassis and 4banger ?
