Technical Nothing say's gut punch more than finding water in the oil in your Flathead * UPDATE *
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 11, 2016.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Last night water was found in the oil of the Confused pickup.
    The truck has been running like a top and has made several trips around the block and everything was looking good for this weekends maiden voyage to Kentucky,Dave decided to change the break in oil and was shocked when he removed the catch pan.
    Now trying to figure out the next step,he spent a ton on that engine. HRP
  2. lothiandon1940
    lothiandon1940
    Dang, that's disheartening to say the least. Had the head-bolts been re-torqued after the first heat cycle?
  3. belair
    belair
    at least it wasnt the crank
    HOTRODPRIMER and dogwalkin like this.
  4. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    As said above Re-torque the heads
    HOTRODPRIMER and lothiandon1940 like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I really don't know,this is Dave's first Flathead and he just might not be aware
    of the need to re-torque the bolts.
    I also know he changed the intake after the engine was rebuilt.
    Posting the problem here just might result in a easy fix and just might not be as bad as he thinks.
    Thanks guys
    mctim64 likes this.
  6. 53 ford
    53 ford
    I hate to be negative, but please explain how head bolt torque can leak water to the oil. No water jacket in the intake. Only thing I can reason is crack in crank case. Please prove me wrong. Or crack in lifter valley.
    HOTRODPRIMER likes this.
  7. Mr48chev
    It might be worth investing in a pair of head gaskets just to inspect the engine and be sure of what's going on.
  8. Atwater Mike
    Atwater Mike
    ...or warm up the engine, remove plugs, and pressurize the cooling system. (Stant radiator pump, designed for this purpose. NAPA stocks the Stant pump. Different sizes caps are available...)
    Whichever cylinder pumps water when cranking is the culprit.
    OR: Remove coil wire when engine is cold, radiator full.
    Crank engine over, 4 to 5 revolutions.
    Remove plugs, tap each one on the palm of your hand, look for water drops.
    (Old 'Indian' trick, used it for years...)
  9. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I am not sure where you are going with this but if the heads are loose they will leak water down the bore and into the crankcase.
    Old Hot Rodders rule of thumb was to run the motor for 20/30 minutes then let the motor cool completely down and retorque the heads. Also after 400 to 500 miles retorque them again.
  10. tb33anda3rd
    tb33anda3rd
    Danny, antifreeze or water? could it be condensation? i heard it could be a little humid down there.:rolleyes:
  11. HOTRODPRIMER
    HOTRODPRIMER
    Antifreeze/water,there is a dehumidifier in the shop.
    As for humid,oh yeah and hot,several 99 degree days in a row.
    It's so hot the chickens are laying hard boiled eggs & the cows are giving evaporated milk!:confused: HRP
  12. lothiandon1940
    lothiandon1940
    ....................That's hilarious!...Well....unless you're there having to deal with it.:)
  13. Kiwi 4d
    Kiwi 4d
    We had a flathead that was fully rebuilt and the machinist ***ured us he had surfaced the block. We had several water seeps from the new offy heads, toque re torque. changed again to Navarro heads and a seal well cube in the water. Still a fail. Anyway long story short we had other issues from the same shop causing us to pull the motor and go through everything again and lightly surface the deck surface. Been sweet for 7000 Mls.
    What I am trying to say is the old don't ***UME . It made an *** of me.
  14. All I can say is I've had a grand total of one flathead built. And I was surprised how much the bolts initially needed to be retorqued.
    This is all despite the fact machine shop put one gasket in backwards (upside down??) And it let go after an hours running.
  15. J'st Wandering
    J'st Wandering
    Interested if hearing if retorquing the head bolts solve the problem. On my motors, I go across the bolts with a torque wrench several times, after the motor has cooled.
    Neal
    HOTRODPRIMER and need louvers ? like this.
  16. millersgarage
    millersgarage
    I've read that you need to torque them heads at least three times.
  17. The heads must be re torqued every time the engine has run up to temp and cooled as many times as it takes until the nuts do not take anymore turns from the torque wrench. I have done the retorque 5 times on my current engine when I installed the offenhauser aluminum heads. The expansion and contraction of the iron and aluminum cause the heads to walk around a bit as the gasket settles in. This is not an optional procedure. Blow a head gasket and you'll need to resurface the heads.
    S.F. and HOTRODPRIMER like this.
  18. big duece
    big duece
    from kansas
    Head studs/bolts require a sealer, right? I will be doing this later this year with my engine.
  19. Correct, any fastener that is open into a water jacket or oil source should be sealed. I will note that studs are easier on the threaded holes in the block than bolts and more accurate torque is achieved. If they are new studs, I usually lightly torque and loosen them 3-4 times to smooth the stud and nut threads out before going to final torque. Should be done dry, no oil or ***embly lube.
    belair and HOTRODPRIMER like this.
  20. big duece
    big duece
    from kansas
    The 3-4 torque sequence I have heard of with rod bolts, and a good idea all around. Is this for the stud to head, as well as the nuts that hold the heads on?
  21. arkiehotrods
    arkiehotrods
    I had the same thing happen a decade ago with an 8BA flathead. Drained oil and a ton of anti-freeze followed the oil out the drain plug. Re-torqued the heads, no more problem. Oil stayed water-free.
  22. Yes just the hold down nuts, I do clean the block threads with a thread CHASER before installing the studs. I do not recommend a tap because taps are for cutting threads and they will weaken the existing threads by removing material as you run it through, then you risk pulling the stud out of the block as you run up on the final nut torque, thus making a threaded insert repair necessary. Some will probably chime in and say a tap is probably fine. I say there is a correct tool out there for every job.
    stillrunners and HOTRODPRIMER like this.
  23. big duece
    big duece
    from kansas
    I have also seen where a original head stud has had flutes cut lengthwise for chasers.
  24. cretin
    cretin
    That is what i did. It worked well. I saw a lot of people saying to not use a tap because the stud threads are rolled, and won't work as well if a tap is run through. So I used a modified stud, and now have another flathead tool.
    I would check the torque on the heads, and if that didn't work, pop those heads off and investigate.
    I just spent more then I wanted to on a flathead build, and if it were me, purchasing another set of head gaskets so you can be sure there are no bigger issues is worth it.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
    Also if you haven't had luck with retorque. Check surface flatness of block and heads.
    If the engine was properly checked before machining. There should be nothing to be concerned about. I sure hope this is the case.
  26. HOTRODPRIMER
    HOTRODPRIMER
    From what I understand a man they call Putt or Putman rebuilt the engine and supposedly has a good reputation in the Atlanta/Lavonia,Georgia area. HRP
    lothiandon1940 likes this.
  27. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    A noted old car guy here had just put a new flatty in his 36 coupe. I saw him at a car event and he was mentioning that it was starting to run warm. I asked him if he had retorqued the heads, I got the deer in the headlights look??
    So I asked him to open the hood. I took half the nuts off the heads with my fingers and gave them to him saying these are a bit loose!!!! We did a ratchet and socket light tighten job that got him home where he retorqued the heads and all was well after that.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Fuzzy,that is proof positive that even the seasoned hot rod veterans can sometimes overlook a step in the care & maintenance of a fresh Flathead engine. HRP
    shawnsauto1 and lothiandon1940 like this.
  29. Rex_A_Lott
    Rex_A_Lott
    I've never had the heads off a V8 flathead, but this torque/heat/retorque is SOP on an A-Model Flathead, as many times as it takes, as was mentioned. I'd also drain all the anti-freeze out and just run straight water until I was sure i had it sealed up. Anti-freeze is hell on bearings. Lota of people dont like it, but a lot of the old-timers put in a jar of bars-leak to stop the little seeps.Good Luck
  30. HOTRODPRIMER
    HOTRODPRIMER
    Thank you my friend,with all the knowledge posted on this thread it may help others benefit from this experience and avoid problems in the future. HRP
