Nova Clip Question
Discussion in 'The Hokey Ass Message Board' started by Nimrod, Feb 10, 2006.
  1. Nimrod
    Nimrod
    What year front suspension clip came with the front mounted steering box? I've got a clip under my truck I thought was a '75, but I'm not sure. I've got to pick up a couple new brake calipers at lunch (one froze up on my way to work today). So I just wanted to make sure I knew what to ask for. Someone told me a little while back that the older style clip (with the rear mounted box ran until '76? Brake calipers may be the same anyway, but I don't know?
    Thanks - Jeff
  2. Slag Kustom
    Slag Kustom
    later nova had a front box. camaro is also the same from 70 up
  3. MercDeuceMan
    MercDeuceMan
    from Indiana
    I've got a 78 Nova clip under my truck and it is a forward steer clip
  4. chopolds
    chopolds
    from howell, nj
    Camaro switched to front steer in 70, Nova in 73.
  5. dt50chev
    dt50chev
    68 to 74 Nova=rear steer
    75 to 79 Nova=front steer
  6. Bass
    Bass
    from Dallas, TX
    Brake calipers should interchange between years. I think there are some minor differences in the rotors and spindles between '68-74 Novas, and '75-79, but I believe the calipers are the same.
  7. Nimrod
    Nimrod
    Allright...thank you all.
  8. novadude
    novadude
    This is correct. I *believe* that the calipers changed to metric in 1977 too. I am not 100% sure though. I DO know that 75-79 Novas were the only front steer ones.
