Nova or camaro subframe on 57 chevy pickup
Discussion in 'The Hokey Ass Message Board' started by Welsh379, Aug 12, 2011.
  1. Welsh379
    Welsh379
    Hi Im putting a Nova subframe on my 57 chevy pickup just wondering if anybody has done this before to help me out?
  2. Abomb
    Abomb
  3. CMG1973
    CMG1973
    from Arkansas
    No-Limit Engineering has a video on how to do it for $15 bucks. it was filmed in about 1982 but the information is good. it's a little different way to do it than the way mentioned in the post above.
  4. zman
    zman
    from Garner, NC
  5. CB_Chief
    CB_Chief
    from Oklahoma
    I have that video and it is pretty dead on. I have driven almost 40K miles on my '58 Apache and the only thing I can think of that should have been addressed a little better was the fact that the steering might be overly sensitive once everything was set up and running. I cured the problem by replacing the bypass valve in the power steering pump with on designed for use on rack and pinion conversions using the Mustang II stuff. I don't remember who makes it, I bought the valve at Parr Automotive in Oklahoma City but I am sure it can be found at other places.
    If I was doing it all over again, I would cut the column and shaft off of my original steering box and adapt it to the later model steering box rather than use the Camaro tilt column. Since I don't want to go back and do this I am going to install my original steering wheel on the Camaro column this winter when I rebuild the front suspension. I have done some test fitting on another column I have sitting in the shop and it looks like an easy job.
    By the way, you should go post an intro to let us know more about you. If you had read the rules you should know that this is a requirement. It will also keep you from getting verbally beat down by some less forgiving members.
  6. rusty1
    rusty1
    ...here's one I just did, 72 Nova in a 55 p.u.
