Hot Rods Nova rear drum brakes
Discussion in 'The Hokey Ass Message Board' started by phat rat, Dec 22, 2025.
  1. phat rat
    phat rat
    After 20+ years with disc brakes on the rear of the 41 I'm thinking of going back to drum brakes. I've never really been happy with the Cadillac disc brake adjustment and parking/E-brake. Can anyone tell me if the 12" backing plates from a 70's Impala will bolt up in place of the stock 9 1/2" backing plates on a 74 Nova 8 1/2" 10 bolt. It would be nice to be able to go to the larger brakes
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. phat rat
    phat rat
    That's good info but doesn't show what I need
  4. 31 Coupe
    31 Coupe
    I appreciate that this info isn't directly addressing your question but I had to narrow my 10-1/2" 10 bolt by 2" to suit my new tire and wheel fit.
    By sheer luck I found that Aussie VN Commodore 28 spline axles were the perfect length and fit.
    But, I was also wanting to upgrade to rear discs and again by luck a pair of Aussie "Ford AU2" Borg Warner units became available to me, plus these brakes have a good performance reputation. The bonus was to now have conventional sealed roller axle bearings instead of the dangerous Chevy C clip style units.
    Long story short, I designed and machined a pair of new housing ends to accommodate both the Commodore axle bearing plus the AU2 backing plate ..... they got welded onto the 10 bolt housing. That gave me a 1500mm (59") WMS to WMS dimension.
    So, here's where I'm coming from .... maybe try to find another style 28 spline axle with an appropriate length, both Ford and GM are the same spline profile. There's then a good chance that commercially available housing ends could accommodate both the new axle bearings and suitable drum brakes.
    If you find an appropriate Ford axle, the Torino housing ends take a diverse range of bearing ID sizes plus 11" x 2-1/4" drum brakes.
    I apologize if this is too deep for what you are trying to achieve.
    Rich796 likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Both 70 Imp & 74 nova both use a
    2 inch wide shoe , Rear
    Both have the 4-3/4 bolt circle
    Rock auto your Friend
    Deuces likes this.
  6. phat rat
    phat rat
    I know that but my question is will the backing plates for the 12" x 2" brakes bolt up to the 8 1/2" 10 bolt which only has a 9 1/2"x 2" brake shoe. I know the drums are 4 3/4" bp and will interchange
  7. 19Eddy30
    19Eddy30
    from VA
    I found talk on other sites , one Chevelle form ...
    My self I can not find a spec / measurement on backing plates.
    About 30-40 mints .
    I am like most just want to bolt on with little to No mods Now days Thats not all way's case ....if a difference's on flange mount ,
    In my thinking & If I want to do
    I would take what ever size hole saw
    Cut the center of 10 B-P & 12 B-P
    Out , Tig weld the 10 Bolt into 12 bolt Backing Plate ...
    Or
    I wanted bigger rear dic ,
    cardboard , plasma cutter
    Make my on kit mouthing brackets
    For bigger dic & caliper ..
    Not trying to be a Smart A$$ !!
    I make one off items , I have Tools , I guess most do not ...
    I also use the Cadillac calipers on 2
    9 inch , both I feel fast rides 100 mph in 1/8 & Street drive 3,000 pd .
    Even set up 30 A with stock dic S-10 3:43 rear with 427 sb on plain Radial tire , 105 mph in 1/8 , did not break .
    On Sticks Yes I am sure it would have .
    Tow Truck Tom likes this.
  8. phat rat
    phat rat
    19eddy30, thanks for the reply. Yes sometimes you just need to modify something to fit. I had to reclock the Caddy brackets and add spacers in order to do the conversion
