nova sub frame
Discussion in 'The Hokey Ass Message Board' started by terrydrace, Apr 17, 2013.
  1. terrydrace
    terrydrace
    from iowa
    Got some pic in album no room to get cam in their pic of front and back to show how car sits
  2. So ....I guess you're just not going to give us the information from the two alignments:confused: Well OK......good luck with this........
  3. As I (and others) posted earlier, the caster number is still a little low. That combined with the play in the wheel is likely causing the wandering. It's hard to tell if the car is at ride height in the photos you posted, but the camber looks off as well...
  4. terrydrace
    terrydrace
    from iowa
    The only thing the alinmet guy said when i brout it in was their was to many shimes in it 1st time 2 time said nothing.Im going to change steering box find a diferant alinment guy.thanks guys
  5. srs1
    srs1
    what condition are your rear springs, shackles, u-bolts etc.? is everything tight back there?
  6. terrydrace
    terrydrace
    from iowa
    changed front of sring bushings not back shackles and some times it does radel a littel u-bolts are tight. Mabe better change shackle bushings
