November 2009 Banger Thread
Discussion in 'The Hokey Ass Message Board' started by A-zonie, Nov 1, 2009.
  1. Crazydaddyo
    Crazydaddyo
    Andy,
    If the person drilling the crank is careful, and understands that you aren't going to grind it, You shouldn't have to.
  2. kirby1374
    kirby1374
    thanks, i skimmed and didn't read the whole post. I did not buy a diamond block. I hope to fire it up soon though
  3. jim galli
    jim galli
    So, Diamonds can be either a Model A without the fuel pump and with the oil return, or a B type with fuel pump and without oil return. If it's an 'A' with the diamond is it likely to have all the smaller Model A stuff internally? Or did the 'A' with diamond have the bigger crank with or without counterbalances? Now I'm really confused. :confused:
  4. Crazydaddyo
    Crazydaddyo
    Yes. Think of it like this.
    A diamonds are 1931 A engines built after 1931.
    B diamonds are 1933 B engines that were built after 1933
    Here is a good quick read on the banger basics:
    http://1149.ca/banger/Fundamentals.pdf
  5. fur biscuit
    fur biscuit
    so, i did some cleaning on my block, it is not a diamond block, but it does have "C" cast in the head. Just need to drop the pan and see what I really have.
  6. ebtm3
    ebtm3
    There are four counterweights. All are the same inside diameter. The A,B and BB cranks all have a disk area turned four places- behind front main, either side center main, and just ahead of rear main. All are the same size and the counterweights can be put on any position on any of these cranks. The center two have to p*** over the end diameter to get to where they will go. How Ford managed this with a heavy press fit I have no idea. The only way that I can see is that they heated and shrunk them on. If you have a very tight press fit, many times you will get galling during pressing. In the ones that I took apart there was no evidence of this, and with the rough surfaces on the crank and bore of the counterweight, I can,t see this not happening if a press rather than a shrink fit was used.
    Herb Kephart
  7. RussTee
    RussTee
    Im organising a display of bangers here in New Zealand dont think it has been done before featuring hotrodded modified or speedster type vehicals and parts mainly ford a and tees and a few vintage speedway type cars these type of cars have always been looked down on her by both rodders and vintage car types so it has been an uphill battle all the way how ever by all working together about 60 car owners have indicated they are interested along with a number of owners of period speed equipment overheads ect any suggestions as to other displays that may help promote our interest.[maybe copies of old banger speed adds if anyone has any]
  8. Kiwi Tinbender
    Kiwi Tinbender
    Russell...When are you having your event? Maybe you can get Greg to come South and take some pictures...would like to see some on here....
  9. RussTee
    RussTee
    yep Greg was hopeing to come but I see he has the tee up for sale hope he keeps it long enough to come down it will be a display only in conjunction with Craigs muscle car madness the 20th which runs from jan 21 to jan24 the display will probably be on the24th this is New Zealands largest event with overseas bands meals arun and all kinds of events I really dont know how Craig manages one event like this let alone 20 a magnificent effort and world cl*** he he should see the burnout pad in action let alone the party legendary ya think Kiwis at Bonneville could party ya should see them on their home ground
  10. Still hoping to come down somehow.
    I am hoping I do sell but hoping I dont if that makes sense.
  11. Niklas sweden
    Niklas sweden
  12. Fro
    Fro
    from Joplin Mo.
  13. Bigcheese327
    Bigcheese327
    I would also love to see pics of the coupster. The video was a bit of a tease.
    -Dave
  14. 97
    97
  15. Niklas sweden
    Niklas sweden
  16. Artiki
    Artiki
    from Brum...
    That's the ***s! Love the build pics.
  17. Niklas sweden
    Niklas sweden
    The blower is a aircraft cabin pressure blower thats have bin modd to fit a engine.
    Belt drive throw a Vw Typ 1 generator, the engine its a stock B. 2 bbl autolite carb, going to replace it with two -97 carbs later. Stock ch***ie with a -32 hevy axel in front, a small kickup in the bak 2". 16" with 500 ribb/750-16 firestone rubber. im hoping to put out 100hp with this set up. The body is pieces from several cars, quater panels from a coupe, very much home made parts and modifikation to the body to make it look good (6 kvm new sheetmetal), home made "Hallock" windscreen. Old cheaster gray paint.
    Sorry! very bad english =)
  18. Your English is 100% better than my Swedish...
    The drive through the generator is ingenious!
  19. Fro
    Fro
    from Joplin Mo.
    Thanks Nik, your english is just fine.
  20. Rivet
    Rivet
    That is one bad *** coupster! Good job do***enting the whole adventure.
  21. Crazydaddyo
    Crazydaddyo
    Nik,
    I'd say that 100 hp is no problem. What a *****in project !!!!
    Do you know how much boost the blower is puttin out?
    Thanks
  22. Niklas sweden
    Niklas sweden
    I dont know how most boost but its almost twice the rpm that the engine is turning.
    I have 2" exhaust but have to change it to somthing bigger now with the blower instald. I have some air leak that i have workt on today, new gasket and stuff so now i will run iven grater. More vids coming later.
    Im building another supercharged banger allsow, its a Volvo B20 (2000CC) with a Volvo marin blower and two 45/45 weber on it. That i hope will put out 300hp, its going to bee instald in a -28 tudor later. That blower going to peak 13000 rpm and the engine 6500 rpm. That going to boost around 3 bar in top peak. 3 Bar = tripple effekt. The blower on the coupster maybe put out 1-1,5 bar on peak rpm and that on a sidvavle engine will esaly dubble the effekt i think. maybe tripple it?
    I think the blower its a 1,5 liters i dont now how to kalculate it but maybee 1,5 * 8000rpm = 12000 liter och air? maybee someone can kalculate the hp in the engine?
    Pics of the Volvo banger maybee i put out here if you guys are interested in such a motor?
  23. BCCHOPIT
    BCCHOPIT
    Holy **** you guys have been having fun the last two weeks. My hard drive in my laptop **** the bed so I could not come out and play.
    hey daddyo is your new avatar you as a kid :)
    thanks for all the cool post guys
    later Bill
  24. BCCHOPIT
    BCCHOPIT
    My boss
    took some pics of a cool cut away model A engine for me.
  25. Artiki
    Artiki
    from Brum...
    Ha...I've got a crank that will go with that engine!
  26. Bigcheese327
    Bigcheese327
    Love that signature beneath that last pic. It looks very literal.
    -Dave
  27. BCCHOPIT
    BCCHOPIT
    the guy might trade cranks with you Artiki
    [​IMG][​IMG]
  28. Crazydaddyo
    Crazydaddyo
    This is a great picture. It really shows how thin the stock head is over the piston. If you cut any more then an 1/8 inch off of that head, It would weaken it horribly. I would also predict that there wouldn't be a noticeable change in HP.
    My $0.02
    Thanks for posting the pictures !!!!!
  29. thepolecat
    thepolecat
    cool pics there- that helps the new banger guys like me really understand the inside.
