Technical Now I know how to remove switch knob!
Discussion in 'The Hokey Ass Message Board' started by seabeecmc, Nov 26, 2023.
  1. seabeecmc
    seabeecmc
    I need to remove the knob on this style wiper motor. I've pried as much as I dare and attempted to unscrew without luck. Appreciate knowing how someone has removed one without damage. Ron whip.jpg
  2. AccurateMike
    AccurateMike
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    I just bought one of those a couple months ago and installed it behind my headboard. I needed to install a separate switch so I tried removing that knob with no success. It will break, it has a strange cheap plastic connection, not anything you’d expect, the knob reaches clear inside the unit.
    I ended up leaving the switch to the on position and running the Hotwire to a separate switch.
  4. BJR
    BJR
    Why did you need a wiper on your bed? What are you wiping? :p
    SS327, '34 Ratrod, Petejoe and 3 others like this.
  5. Tim
    Tim
    from KCMO
    Do you really want an answer to that question?
    SS327, '34 Ratrod, BJR and 3 others like this.
  6. theHIGHLANDER
    theHIGHLANDER
    Not all squirters are mounted on the hood...o_O
    Bandit Billy, loudbang, SS327 and 3 others like this.
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    My squirters location is a personal matter.
    Right away I was thinking you guys were talking about a truck bed. Creeps. :) :) :)
    SS327 and BJR like this.
  8. theHIGHLANDER
    theHIGHLANDER
    Wait, what? Not what I meant, but I see what you did there.
    BJR, SS327 and Petejoe like this.
  9. You could try playing a heat gun on there, just carefully so it doesn't start burning, and try prying it off. Although it sounds like it is a thermoset plastic, so heating it won't do a thing. If you don't care about keeping it, bust it off. Replacement knobs would have a grub screw ,or the shaft could be a metric spline, knobs available for these, too.
  10. inthweedz
    inthweedz
    Does the whole top cover come off?, from memory (on an older but same looking w/motor) the cover was able to be removed, and a clip was on the inside securing the switch pivot..
  11. gary macdonald
    gary macdonald
    Whole top cover comes off with that one screw. The switch is a piece of copper that hits the contact .
  12. seabeecmc
    seabeecmc
    Actually the knob is held with a screw through the cover to switch as shown. Ron wipemot1.jpg wipemot2.jpg wipemot3.jpg wipemot4.jpg wipemot5.jpg wipemot6.jpg wipemot7.jpg wipemot8.jpg
