Technical Nu relic power window replacement motor
Discussion in 'The Hokey Ass Message Board' started by 440 deluxe, May 7, 2016.
  1. 440 deluxe
    440 deluxe
    Does anyone know what motor/ part number nu relic uses for there power window kits? Got a lazy motor!! ImageUploadedByH.A.M.B.1462659686.742257.jpg
  2. HOTRODPRIMER
    HOTRODPRIMER
    Before you replace it make sure you have a good ground.
    Summit carries a line of replacement PW motors,you could probably find one like yours .HRP
    replacements
  3. 440 deluxe
    440 deluxe
    HRP thanks just found a dorman motor I think will work. O'reilly also has them I will pick one up after church[emoji16]
  4. Gman0046
    Gman0046
    440, lazy lift motors usually require replacement. My 63 BelAir's drivers window would not close with out helping it. The lift motors are Ford. I couldn't buy a replacement locally so I bought a Dorman universal lift motor from Bumper to Bumper Auto Parts for $40. A small slice with a die grinder adapted it for my installation. If all else fails, I'd contact Nu-Relics. They advertise their new lift motors are AC Delco.
    Gary​
  5. mgtstumpy
    mgtstumpy
  6. 440 deluxe
    440 deluxe
    So i went to advance auto after church and after a little searching i found a motor ( part number 82458) that matched up perfect. Delco motor. 30 bucks. Window is cooking now!!! thanks for the help
