Nutserts
Discussion in 'The Hokey Ass Message Board' started by blowby, Oct 5, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    Are these the hot poop to put threads in square frame tubing?
  2. R Pope
    R Pope
    They work great. Just remember to torque them down fully the first time, they can strip out in the hole if you don't.
  3. ryno
    ryno
    yes, put keep in mind they are not designed to take a lot of stress.
  4. Love them / hate them.... see above advice...
  5. HOTRODPRIMER
    HOTRODPRIMER
    I've used them but I wouldn't depend on them to hold the body on the frame. HRP
  6. blowby
    blowby
    from Nicasio Ca
    Thanks guys. Somewhere between a self tapping screw and a welded tab sounds like.
  7. Lukydevl
    Lukydevl
    from Arizona
    I use the steel ones all the time.. Rated for aircraft, what has more stress than that??
  8. Great for holding access covers, mirrors, door handles, and other low load stuff like line clamps.
    I wouldn't use it to hold ch***is components, muffler hangers or a body.
  9. Normbc9
    Normbc9
    We use them routinely for the tool mount brackets in our Fire Apparatus fleet. Have done so for 20+ years with great success.
    Normbc9
  10. crminal
    crminal
    Saw them used by Brookville in one of their frames as body mounting points. Just sayin'
    I'd like to do the same but am a bit skeptical.....
  11. Clik
    Clik
    What's the weakest link? Probably the sheet metal.
  12. Blue One
    Blue One
    from Alberta
    They are awesome, I use them almost everywhere. Use the steel ones you will never have issues with them.
    There are heavy duty versions available that spread out differently on the back side and hold a lot of weight or torque.
  13. pitman
    pitman
  14. Blue One
    Blue One
    from Alberta
  15. I hate the *******s, may be great in Cali, but in Wisconsin a little rust in the threads and they spin in the holes and you are screwed trying to get bolts out. The only place/time I use them is where/when I'll never have to dis***emble them again!
    If you need bigger stronger threads in thin stuff, weld on an overlay or drill a bigger hole and weld in a bung and tap it.
  16. Blue One
    Blue One
    from Alberta
    Rust will never be an issue in my hot-rod :)
  17. saltflats
    saltflats
    from Missouri
    Funny how stuff pops up I was just getting ready to use some for a fuse panel mount bracket.
  18. Yeah, there's nothing more frustrating as one of these things spinning in the hole. I've used them, but only the steel versions and I'll put a couple of tack welds on them, as well as using antiseize...
  19. WornOutOldMan
    WornOutOldMan
    from So Cal
    Dissimiliar metals (different fastener vs nutsert material) can also be problematic as they can/will develop corosion. A little dab of anti-seize is your friend. ;)
  20. Fenders
    Fenders
    Yes, be sure to use the antiseize on every bolt !
  21. stimpy
    stimpy
    if you can find the steel ones and installed right they are quite strong we used them on trucks all the time as your not allowed to weld to the frame and in some spots you cannot access the back side of part to be bolted . the ones I use are a cone style not aluminum pop rivet style you have to use a impact gun or the special press to pull them like a huck bolt in place . the aluminum ones are garbage . and you should use anti seize on the threads of the bolts when using them so you can get it apart later on .
  22. Blue One
    Blue One
    from Alberta
    Steel bolts and steel nutserts. Sounds good to me. Thats all I use and they work very well.
  23. Bearing Burner
    Bearing Burner
    from W. MA
    Use the RIGHT size drill and the proper insertion tool.I personally don't liker using larger than 1/4" bolt size.
  24. fordor41
    fordor41
    I've used them with all the above results. I drill a hole slightly smaller, file to "just" fit the nutsert and crank them down good with the installation tool. Better choice for any load is a caged nut
  25. go-twichy
    go-twichy
    good for light use only, i've bent the instalation tool putting them in to.(american made) i love the idea of them, being able to put threads from one side only, but for me they have not lived up to their reputation yet. to the guy building airplanes with them... i dont know about if thats a good idea. may on some drink holders or a map holder.
  26. ronzmtrwrx
    ronzmtrwrx
    There are many different varieties of "nutserts". I use a lot of the 10-24 and 1/4-20 sizes. Do your research, as some styles are ****. I only use the cad plated steel, ribbed style. I get mine from McMaster Carr. Do NOT use those that break in the middle and pull the threaded portion up into the barrel. I have used those in the past, and had them work loose. I have had excellent results from the style I now use. Anything larger than 1/4", I would recommend welding in a threaded bung.
  27. bobkatrods
    bobkatrods
    from aledo tx
    I worked on aircraft for 35 years ,28 with the airlines, they are used quite a bit, Only they are called RIVNUTS and are made different than nutserts.If you have ever flown on a airline, You have parked your **** over hundreds of them.
  28. go-twichy
    go-twichy
    if he had asked about "rivnuts"i would have had no comment to make, but he was wanting to know about "nutserts". you should show a pictures of the ones you're talking about, I know I would like to know more about them. or do a torque test with them to show what they can do before they fail. anybody set up to do a test on both? i'm on the edge of my chair just thinking about it!
  29. Kiwi 4d
    Kiwi 4d
    To fit panel steel parts to panel steel they are the ducks nuts . But for structural stuff even with the large flange nutsert jobs I would have my doubts. We recently fitted a deck lid to a project and it was probably more than they were intended for and two nutserts spun in the thin panel steel and OH MY what a ***** to remove. But I would sur still use them in low stress applications every time.
  30. k1w1rodder
    k1w1rodder
    ^^^^^^^^^^^^^^^^^what he said, used them for years, great for cable and brake line installs, small componants. fine for shear type forces not so much for pulling forces. Probably wouldn't use anything bigger than 1/4 / 6mm. Steel inserts, steel bolts, antisieze. Nothing like repe***ion:D
