O.D trans
Discussion in 'The Hokey Ass Message Board' started by Chewie46, Aug 18, 2011.
  1. Chewie46
    Chewie46
    I have a stock 48 Stude O.D. 3speed trans. Do I need to use a voltage drop to use it in a 12 volt system?
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    Chewie46
    I think that you have a Borg Warner OD. If so, you'll need a 12 solenoid. I don't think a voltage drop will work, as the solenoid current draw is pretty high.
    Jim
  3. RHunt
    RHunt
    yeah, i had a resistor on mine and it didn't like it. swapped to a 12v solenoid and works great now.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Fords and Studebaker O.D.'s in many cases interchange, a 12 volt Ford solenoid is easier to find and will work in your Studebaker.They show up on "evilbay" fairly often.
