O/T 70 cuda spec.? Anyone
Discussion in 'The Hokey Ass Message Board' started by MIKE47, Jan 25, 2008.
  1. MIKE47
    MIKE47
    from new jersey
    I know this is O/T but I figured I'd give it a shot. I am doing some resto work on a 1970 plymouth cuda. I need to know the distance apart the rear leafs should be at the axle pads. Either pin centers or inside to inside once assembled. Something ain't right in this car and I need to figure it out asap. I know someone on here has one of these cars or knows of a good mopar website. Any help is appreciated. Thanks, Mike.
  2. 6t5frlane
    6t5frlane
    from New York
    Allpar.com I think is a good Mopar Forum
  3. JOECOOL
    JOECOOL
    I don't have the spec but I do remember the springs don't set paralell with the frame. Hope that helps. best of luck.
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    they taper in from the front...Like a shallow "v"
    The pins aren't centered in the springs, either. they sit about 1/3 down from the front bushings.
  5. texascuda
    texascuda
    from Dallas, TX
    GO over to Cuda-Challenger.com or I can give you the spec's on Saturday.
    Regards,
    Steve
  6. SinisterCustom
    SinisterCustom
  7. RodStRace
    RodStRace
  8. moparron426
    moparron426
  9. MIKE47
    MIKE47
    from new jersey
    Thanks guys. I really appreciate the help. Guess I gotta cut off the pads. They are 44". They were just done by another shop "to factory specs." Guess they got the specs. from the wrong "factory".
    I knew they tapered in towards the front and that there was a left and right. Now I just gotta pull it all out and start over.
