O/T..Compressor I.D. help?
Discussion in 'The Hokey Ass Message Board' started by GTS225, Aug 6, 2009.
  1. GTS225
    GTS225
    Got 'hold of a Curtis compressor pump, but the data plate has been removed at some time in it's life. Have went through Curtis's website, and through the books at a local compressor service company we deal with, without success.
    You guys seem to be the best referance library in the world, so I'm coming here in the hopes somebody has that little bit of info I'm looking for, or maybe even some parts laying around.
    I'll do a duplicate posting on the Garage Joiurnal board as well to maximize this.
    Here's what I know; low pressure piston dia.: 3-3/8"...high pressure piston dia: 1-5/8"...stroke; 3".....flywheel dia; 14"
    lp rod casting #; DU4B
    lp piston casting #; DU5B
    hp rod casting #; DU4A
    head casting #; DU-6-IX
    front crank bearing retainer casting #; DU2A
    cylinder ***embly casting mark; "90"
    Thanks in advance.....Roger
    http://i134.photobucket.com/albums/q107/GTS225/compr003.jpg
    http://i134.photobucket.com/albums/q107/GTS225/compr002.jpg
    http://i134.photobucket.com/albums/q107/GTS225/compr001.jpg
  2. ablebob
    ablebob
    I had one years ago. I don't know the model. It had a 3hp motor & a riveted tank. I remember it was built in 1939. Wish I could help more.
  3. GTS225
    GTS225
    WOW! Nobody? I stumped the board?!
    Roger
