Technical ***October 2023 Banger Meet Thread - Halloween Month***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 1, 2023.
  1. Derek Mitchell
    Derek Mitchell
    Still collecting parts for mine.
    I got a cam from a regrinder and he mentioned it was a Winfield grind@ .330 lift. Does anyone have a list of Winfield banger cam grinds?
    fur biscuit likes this.
  2. Has anyone mounted Model A axles, engine, and transmission onto a stock T frame before?
    Outback likes this.
  3. Outback
    Outback
    from NE Vic, Oz
    Not exhaustive, but might help
    In short yes, many times,
    Look up @Greg Stokes Fireball T it's as cool as a cool thing. ;)
    Derek Mitchell likes this.
  4. Derek Mitchell
    Derek Mitchell
    Outback likes this.
  5. brokenspoke
    brokenspoke
    I cant imagine anyone doing this...
    51 mercules likes this.
  6. 282doorUK
    282doorUK
    Just bought me a '31 Ford model A sports coupe to join my two '28 Chevy bangers, so not much brand loyalty going on here, ha ha.
    It has gl*** fibre fenders/wings, running boards and aprons, lighter more speed?.
    Knowing nothing about Fords I didn't spot the 'B' marked police head and Carter 245 SD carb on it when I bought it.
    It does go surprisingly well, I think I may have stumbled upon a ready made hot rod!
    Presuming it's got a stock cam, would anyone like to make an educated guess at the HP might be with those mods?
    It just needs all the bling taken off and a little rubber rake now to be almost perfect.
    Who's a happy chappy then :D
    Here it is parked next to my '28 Chevy racer
    GuyW, Outback and Crazydaddyo like this.
  7. Thank you!!
    It would be a Model T with the heart of an A...
    Outback likes this.
  8. 29 Speedster
    29 Speedster
    from Colorado
    282doorUK
    “Presuming it's got a stock cam, would anyone like to make an educated guess at the HP might be with those mods?”
    This is Dyno results that Dennis Piranio made a few years ago. Dennis p***ed away from COVID, his wife Beth still has the parts business, but the machine shop is no longer there. This will give you an idea of modifications change performance. The dyno runs were in Texas, lower al***ude.
    http://modelaparts.net/dynosheets.htm/dynosheets.html
    metalhead140 likes this.
  9. 282doorUK
    282doorUK
    Thanks, that's interesting stuff.
    I'll measure the valve lift to check for a possible cam change.
  10. David Mazza
    David Mazza
    I kept the t rear but model a engine and trans. Model a front axle. This was while in mock-up, I’ve completed all the fabrication and I’m now painting it. IMG_8068.jpeg
  11. And where was it parked? Looks like a local show. I'd recommend Little Ellingham mid-August next year if you fancy a run out.
    Outback likes this.
  12. 282doorUK
    282doorUK
    That was at the FOT, a charity show near Eastbourne, Norfolk would be a good run out, but no problem for a well sorted Model A.
    I have to fix the rattling timing gears and sort out the juice brakes first.
    Outback likes this.
  13. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Is a B distributor considered a perfectly adequate setup for a mild hop-up motor with higher compression, downdrafts, cam, etc., or is something like an FSI a requirement for this scenario?
    Outback likes this.
  14. 62pan
    62pan
    I considered my Winfield engine a mild build. 6-1 head, downdraft, B cam and a lightened flywheel. I ran a stock B dist. for a few years until I found an early Mallory.
    Crazydaddyo and 4BangerDean like this.
  15. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Thanks!
    Is that the engine in your avatar? Winfield S carb?
  16. 62pan
    62pan
    Yes it is. Head is Winfield, carb is Winfield BB model S
  17. 282doorUK
    282doorUK
    Getting to know a bit more about Ford bangers now,.
    The four bolt pump on the police head had me fooled till I spotted the blanked off pump hole, yep my Model A has a B engine in it!
    Took a look at the rattling timing gears and I reckon it's best to avoid aftermarket composite gears!
    I broke a few more teeth off with my fingers, glad it was trailered home as a few more miles might have killed it.
    Am i right in thinking an ally gear is the best replacement?
    Other than that the engine looks very good, bearings have been re-babbited with plenty of shims left, and they feel good.
    As it's a B engine with police head could I expect around 55+ hp?
    Outback likes this.
  18. I always use an aluminium gear. Worth swapping on a new crank gear if you can.
    Outback, Crazydaddyo and 282doorUK like this.
  19. Count me as new to the running driving banger club. Bought this about a year ago- 1928 rpu, hauled it to a friend’s place for show and tell. He suggested we back it into the spare bay. With some great minds and spare hands, including the guy I bought it from, FE74D0C0-8422-43DD-8899-FA39DB952A81.jpeg it was running and driving in a couple of hours, spread over a few consecutive Mondays. It has been a riot so far.
  20. burl
    burl
    from Minnesota
    Checking in
    Digging through my parts pile and building a race car
    GuyW, brjnelson, Outback and 5 others like this.
  21. Crazydaddyo
    Crazydaddyo
    Depends on the cam and carb. my guess is more, but not with that timing gear.
    282doorUK likes this.
  22. 282doorUK
    282doorUK
    Thanks, is there a prefered UK supplier to avoid Chineseium parts or do they all buy in from the same source?
  23. 282doorUK
    282doorUK
    Made me grin, maybe best to get checking the valve lift next.
  24. I normally try to use a Model A drugs mule with space in their suitcase… failing that, I’ve had Adam from Down to Earth ship engine parts in before. Drop me a PM as I have some stuff to get soon.
    alanp561 and Outback like this.
  25. alchemy
    alchemy
    Just bought this at a local swap meet.
  26. RAJO
    RAJO
    My Pop Did look at my avatar
    Outback likes this.
  27. Stovebolt
    Stovebolt
    I'm interested to know more about these magneto's
    How do they function in a 'street engine', given they have little to no advance curve?
    Outback likes this.
  28. choptop4
    choptop4
    Working on getting it running again. Looking for a different distributor. Any ideas?
    GuyW and akkhotrod like this.
  29. burl
    burl
    from Minnesota
    Me to,
    I have a couple of these. They were made to run in stationary or constant rpm situations so advance wasn't necessary.
    A couple things i have found out so far is 6 volt system is necessary and using a manual cable may be a way to get around the advance curve issue.
  30. brjnelson
    brjnelson
    Do you have the distributor drive extension thing Charlie made with that R2P head
    Outback likes this.
