Technical ***October 2023 Banger Meet Thread - Halloween Month***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 1, 2023.
  1. Crazydaddyo
    Crazydaddyo
    I'm using a PCV on two of mine. I tapped into the top rear corner of the valve chamber cover and ran it to the intake manifold. I had to put a orifice in the fitting at the cover to restrict the flow as it was drawing too much from the crank case. I also made a baffle on the inside of the cover to prevent the ingestion of oil spray into the intake. I also installed a screen in the oil tube cap to keep the rocks out of the crank case.
    choptop4 and 282doorUK like this.
  2. alchemy
    alchemy
    Was it ****ing rocks into the breather? ;)
    Crazydaddyo likes this.
  3. choptop4
    choptop4
    cool beans, pictures please.
    Outback likes this.
  4. D Newcomb
    D Newcomb
    Any video of the McMinville, Or Dirt Drags? Charley H event. Newc
    Outback likes this.
  5. Savage Coupe
    Savage Coupe
    from Washington
    Question, I got these in a hoard of parts I bought. Are these worth using and does anyone have experience with them?
  6. Crazydaddyo
    Crazydaddyo
    I've used them. They have solved the problems I needed solved.
    Savage Coupe likes this.
  7. That is quite a cache of parts
    I have had good success with those
    Just follow the instructions
    J
  8. 282doorUK
    282doorUK
    Well I took it for a 1/2 hr drive today, took the gear cover off afterwards and it all looked good in there.
    Just checked one place at .003 backlash.
    Wear marks on the filed side were slight and biased towards the rear. I thought was my technique, but the marks on the trust side (which hasn't been touched) were also towards the rear. I took off the high spot marks on the filed side, only a couple of light strokes needed.
    It runs very quiet now and I'm hoping it'll run in to around .005-6", and I'm calling it good.
    The filed side.
    The thrust side.
  9. Outback
    Outback
    from NE Vic, Oz
    Good outcome! Hopefully it just continues to settle in
    Have you an oil filter?
    282doorUK likes this.
  10. 282doorUK
    282doorUK
    Yup and I replaced it, cleaned the pan, and changed from the 30wt oil that was in it to 20/50 before the run out.
    Outback likes this.
  11. Outback
    Outback
    from NE Vic, Oz
    Cool. What filter setup are you using?
  12. 282doorUK
    282doorUK
    Byp*** type, it was already on the engine with this filter.
    Old Dawg, BeaverMatt and Outback like this.
  13. BeaverMatt
    BeaverMatt
    Here's one Dale. Filmed from my lil' banger
    GuyW, 282doorUK and Outback like this.
  14. wuga
    wuga
    Time to put the RPU to bed but already planning next year. I am looking for Banger style sand/gr*** drags in the Northeast, Maine, Vermont, New Hampshire, Pennsylvania, New York, Ohio, Michigan Illinois, well I'm sure you get the drift. I am in Ontario, but no problem with a fifteen hour jaunt. Will probably take the Bantam altered to Oxford but Rodtoberfest and Pinetree are a must for the banger. Anytime between May and October.
    Thanks
    Warren
  15. Jiminy
    Jiminy
