Technical ***October 2025 Banger Meet Thread - Happy Hallloween***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 1, 2025.
  1. Jiminy
    Jiminy
    Link to previous month: September 2025 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    22nd Annual North Central Iowa
    Wayne Atkinson Memorial Speed Meet
    Saturday, September 6, 2025
    Worth County Fairgrounds, Northwood, Iowa
    4 miles south of the Minnesota Border, 7 miles east of I - 35
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Here's my banger in my coupe. .040 over, big valves, HOOF head, isky 77b cam, balanced. Gear drive intake with 2 knock off 97s. Lightened flywheel with v8 clutch.
  4. wuga
    wuga
    Just a review, Bert's rebuild some years ago, very little mileage, just replaced head gasket, Brierley 7:1 head, Yapp Equalizer dual intake, running a 97 and what I think is a 48, FSIgnition with 18 degree advance. The engine runs well, but idles at about 1200 and I can't get it down any lower. Is this normal or any suggestions? Thank you.
    Warren
    Outback likes this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    Vacuum leak…?
    winduptoy likes this.
  6. wuga
    wuga
    The propane test doesn't seem to produce any results.
    Warren
  7. PINEAPPLE
    PINEAPPLE
    stromberg bases can be tricky sometimes.. check that your throttle plates are closing all the way, to get you into the idle circuit.. use a uni sync tool to see which carb is pulling all the air in.. a buddy was just having this trouble on flathead v8.. turned out one of the throttle plate screws came out.. big hole to pull air through.. Just a thought for you.. @wuga
  8. Stovebolt
    Stovebolt
    I've been away with work for nearly a month, now back for 10 days, then away on holidays.
    So I put the coupe on jack stands, and I'll prepare it for the summer when I get back.
    Outback, winduptoy and 4BangerDean like this.
  9. wuga
    wuga
    I was just talking with Charlie Yapp and he confirmed a su****ion I had in the back of my mind. Despite any flaws with the carbs, these two combined are too big on his manifold in this application. He is suggesting a pair of 81s will be more than adequate. Both carbs are primaries.
    Warren
  10. alchemy
    alchemy
    A 97 is big, and a 48 is bigger. Both on a banger sounds like too much.
  11. Dan from Oakland
    Dan from Oakland
    Regardless, of size, it should still be possible to get the idle down. Something, somewhere is holding a throttle plate open. I would check the throttle plates on both carbs. BOTH plates should be fully against the bore walls. If not loosen the plate screws and move the plate. Too much carb might not run well but being "too much carb" is not your problem. Just a thought.
    Dannerr, jet996, Outback and 6 others like this.
  12. Nothing too much to report.. I decided to replace the pegboard with some old douglas fir barn wood! Still need to figure out some provisions to mount cylinder heads without damage!
    Wishing I still had one of the original aluminum timing covers I casted, I forgot to include myself in the run when I did them! Screenshot 2025-10-03 at 7.55.02 AM.png
  13. winduptoy
    winduptoy
    just north of 10k miles so far this year on the Vicky....getting ready to trek to the Gathering at the Roc, leaving Wednesday....just going over things and fixing the brake light switch so it doesn't flash the brake lights on rough road....gonna have to gas weld some length on the stem....
    have fun banging down the road boys....
    atch, burl, Retson the Racer and 7 others like this.
  14. s.e.charles
    s.e.charles
    great collection of goodies.
    Q: upper left gizmo? magneto & water pump?
    thanks
    Retson the Racer and Outback like this.
  15. jet996
    jet996
    from WY
    So my p'up suddenly started missing, no biggie I thought. A little troubleshooting I'll get to the bottom of it. Start and idle fine, rev to about 1500 then start missing and get worse the higher the revs. Went through the usual troubleshooting, cleaning tightening checking. No change. Turns out, not One but Two bad new(er) coils. One was a Bosch. I put an old crusty one that was on my roadster when I got it back in 2008 and runs perfect again. You wouldn't believe all the swapping, testing, head-scratching I did thinking the first coil change was ok.. Just to be sure, I put both back on and the symptoms came right back. Strangely, they will do it cold or hot. I'm running the old big br*** Mallory condensor so it appears to have weathered the storm okay. Live and learn...
    Dannerr, Deutscher, Outback and 3 others like this.
  16. jet996
    jet996
    from WY
    @wuga I ran a pair of Holley 94's on my roadster for years and could idle it right down even with a warm cam and light flywheel. Block off one carb base on the manifold and check each of your carbs I'll bet you'll find the issue.
    Dannerr, Outback, G Baese and 2 others like this.
  17. Rather odd ***ortment of parts. It's a Frontenac style Side drive, with a Fronty water pump, and a Robert Bosche FU4 magneto. Manual advance which makes things interesting!
    Dannerr, jet996 and s.e.charles like this.
  18. s.e.charles
    s.e.charles
    "hey look, lady. this magneto ain't gonna advance itself, y'know."
    jet996 likes this.
  19. jet996
    jet996
    from WY
    ^^ Using that line on my wife ASAP:)
    winduptoy and Outback like this.
  20. jet996
    jet996
    from WY
    IMG_8983.jpeg Yes there was wailing and gnashing of teeth... Banged thru a new utility patch that crossed the street next to the shop. The cover rolled across and nailed the curb square on. I was able to get it beat back up straight using some wax backed shipping paper. I think I learned that trick from one of you English gents...
    Only problem is I'll need to polish it to get the road rash out and that means polishing all four. I kind of liked the machined look. Oh well...
  21. Outback
    Outback
    from NE Vic, Oz
  22. brjnelson
    brjnelson
    Score at Hershey scratch 7:1 Iron crowfoot Winfield off my bucket list
    winduptoy, PGA STUDIOS, burl and 9 others like this.
  23. brjnelson
    brjnelson
    When I got home, I found out that the Wico I bought turns clockwise
    I knew I was taking a chance, but to get tach drive was worth the risk.
    winduptoy, burl, 5280A2 and 1 other person like this.
  24. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Over the last year or so, it feels the only times I've hopped on here are to ask remedial questions due to lack of progress with my Chevy OHV conversion. So, allow me to continue...
    I might throw a higher-compression head, a single downdraft intake, and an auto-advance distributor on my A to give me time to get it dialed in, and enjoy, Hot-Rod-A-Rama next year. Also, I need some low-effort horsepower in the meantime... it's big country out here.
    I have a NOS Mallory YS701AVC - other than setting the ignition curve, is there anything that needs to be modified on these before they can be installed? I've seen some with bare shafts, but it looks like mine has the right drive splines.
  25. burl
    burl
    from Minnesota
    Im using one of those on one of my cars. I had to remove the gear and make a sleeve to drive the shaft at the pump. Used a chunk or round stock cut to the right length and added the slots to drive it. I think the slot on the pump is offset.
  26. PGA STUDIOS
    PGA STUDIOS
    from Orlando
    That DOHC 4 banger is bad***!
    Outback and winduptoy like this.
  27. BCCHOPIT
    BCCHOPIT
    just get a bigger cam.... let it eat!!!!!
    winduptoy, Outback and jet996 like this.
  28. jet996
    jet996
    from WY
    And a supercharger, then you won't care about the idle!
    Just trying to be helpful...
    Dannerr, winduptoy and Outback like this.
  29. 5280A2
    5280A2
    I have a NOS Mallory YS701AVC - other than setting the ignition curve, is there anything that needs to be modified on these before they can be installed? I've seen some with bare shafts, but it looks like mine has the right drive splines.[/QUOTE]
    I have built three engines that use this distributor; they are very well made and relatively easy to adapt. That being said, there is a little more to it than has been mentioned so far. There's basically four machining operations involved. The distributor body needs to be shortened, and turned down to fit the opening in the head. The gear needs to be removed and the shaft shortened to expose the part of the shaft that's 0.50 in diameter. The tang that drives the distributor needs to be machined into the end of the shaft. When modified in this fashion a standard sleeve from a Model A distributor will fit on the shaft and can be pinned in place.
    Mallory offered a spring kit PN 29014 that had a wide variety of springs that could be used to adjust these distributors. Not sure if the spring kit is still available but it included some helpful charts showing the curves resulting from various combinations of springs. I am using one gray spring and one orange spring in the distributors I am running on engines with 6-7.0:1 compression heads. The distributor has 24 degrees of centrifugal advance, which is all you need for a high compression head. I use the timing pin and set them straight up at TDC. Found this out the hard way after breaking two Model A crankshafts that I now attribute to too much advance.
    Last year I did a detailed write-up with dimensions on how I modified the distributor pictured below. You can see the changes to the lower part of the distributor by comparing it to the photo in Tumblin' Dice's post. If you would like a copy of the write-up send me a PM with your e-mail address and I'll send a PDF back to you.
    burl, Dannerr, winduptoy and 7 others like this.
  30. jet996
    jet996
    from WY
    That's good info on the springs, I've got one of those that was modded to fit an A, but I haven't run it yet. I'll open it up and have a look. Thanks!
