odd ball cadillac 331-390 speed equipment
Discussion in 'The Hokey Ass Message Board' started by 32coupedeville, Dec 25, 2008.
  1. Torkwrench
    Torkwrench
    Check with Isky. I bought a new Isky E-2 for my 331 in April 2010. At that time they still had brand new cam blanks and could make any grind.
    The speed shop that I got it from had to call Isky directly, and then get ahold of the right Isky employee to get it ordered. Bought an extra cam blank, too.
  2. vtwhead
    vtwhead
    Herbert cams will grind a cam for you. I think B*** had Don there grind him one for his coupe if I remember correctly. Donnie has been there for a long time and is a master at grinding cams. I beleive you can reach him by calling Herbert cams.
  3. nitrohonkey
    nitrohonkey
    I've had great luck with vintage speed. Wish I would have bought my valley pan from them instead of Eelco...NEW,it needed to be surfaced in order to seal.
  4. terd ferguson
    terd ferguson
    My Eelco valley pan needed to have material taken off for the temp sender. I just discovered yesterday it needs material taken off for the distributor to slide down into place. That ****s because I locked down the valley pan and intake after clearancing it for the temp sender figuring it would be good. I didn't have the magspark at the time to check fit.
    Something to be aware of if you're considering an Eelco valley cover. If I had it to do over again, I'd just chrome the stock valley pan. And so not to post without contributing to the odd ball part...
    Magspark redone good as new by GMC Bubba
    390 with Weiand 3x2, Stromberg Model WW carbs, Offenhauser valve covers and et cetera...
    777
    from Pasadena
    The pattern has gone missing, but about 4 years ago a man was recasting them in Norway, I could be wrong about the local though and even though I saw his stuff on line at that time it is no where to be found now.
    I sold this one on Ebay about 3 years ago for I think just over 2k.
    The Hilborn is likely the rarest, according to Stu H they made them for the Allards and a couple dozen casting were foundered but less then that were ever machined and delivered to customers. The original prototype is floating around; it is slightly different with much less casting and more machininig marks on the base; I saw it sell on Ebay it was incomplete and and went for around $1100 then a few months later it was attempted to be re-sold.
    I'll have to load these pics to photo bucket
  6. kadillackid
    kadillackid
    Damn, I think so too :D
  7. 777
    777
    from Pasadena
    The Hilborn is a new old stock I traded Stu for about 4 years ago. My father had purchased one for his 777 roadster in 54 or there abouts and it got hammered sitting out in the Texas sun while the 777 was rusting away waiting to be found.
    That's how I got the rest of the info from Stu about his involvement with the Allards and how many were produced.
    Photobucketed the Cad 2X3 and it turned it into an attached thmbnail sorry... if someone really needs that shot email me direct and I'll send it that way the file is 2.5mb
  8. Louie
    Louie
    from NJ
    man thats some cool stuff 777!!
  9. sawdust78
    sawdust78
    from il
    I have a 1958 Hilborn Fuel injector for a 363 C.I. Caddy.
    It has the matching pump, hoses are all there, have all 8 stacks, I dont know a lot about vintage Cadillac stuff but it seems complete.
    I have copy of original receipt from hilborn, with all the specs,valve size, nozzle size, etc, and everything matches to that original receipt.
    Just was hoping to get some feedback from some people that would know about this thing.
    Thanks
    Hank37 likes this.
  10. jfrolka
    jfrolka
    Its pretty rare!
  11. c322348
    c322348
    Cadillac had a 331, a 365 and a 390 in that series of engine. Cadillac made the 365 between 1956-1958. The ports on the 331 head are smaller. Your unit should fit the 390 as well which used the same heads as the 365.
    I would very much like to see pictures of it!
  12. sawdust78
    sawdust78
    from il
    DSCN1164.jpg [/ATTACH][/ATTACH][​IMG]
  13. sawdust78
    sawdust78
    from il
    Does anyone know how many of these things were made?
  14. c322348
    c322348
    Couldn't have been many! Since they were't very popular, I'd give you $49 for that one... ;)
    Looks to be in great shape.
    If you can measure the port dimension at the gasket surface I can measure both a 331 and a 390 head to verify the application.
  15. sawdust78
    sawdust78
    from il
    I forgot to throw this in the pictures I posted...
    Hank37 likes this.
  16. mart3406
    mart3406
    from Canada
    The Edelbrock marine manifolds are cast
    aluminum and water cooled. In a car, without
    a lake or river full of cold water to circulate
    through them to cool them, they'd melt. By
    the way, Chris-Craft - to name one - and
    several other boat manufacturers too - back
    in the mid-50's and early 60's, offered
    'marinized' versions of the Caddy V8 as an
    OEM option in their boats.
    Mart3406
  17. sawdust78
    sawdust78
    from il
    If anyone is interested in the Caddy Hilborn injector above, it will be on e-bay starting tomm. oct 14th,
    thanks
  18. johnny bondo
    johnny bondo
    from illinois
    you guys think that maybe that transmission bellhousing company might have just made that using a two part mold? it seems like without that one section you could bolt on lets say an early ford trans. so maybe to cut costs they use the same mold and just add the rear section for whatever application they want after the caddy engine?
  19. c322348
    c322348
    Very possible they made the pattern that way so they could interchange the back. The patterns for sand casting are often made of wood.
  20. jfrolka, Are these still available?
  21. SPAM alert:rolleyes:
    O'Brien Truckers has been making a valley cover for the early Cads for 15 years in the USA (and it's been "borrowed" by a couple of other manufacturers.)
    We have them as cast or polished and if you're an Alliance Member you get 10% off.
    http://www.obrientruckers.com/ecom/product/242/2385/
    You will now be returned to your regularly scheduled program.
    Dennis
  22. terd ferguson
    terd ferguson
    I should've bought yours Dennis. The Eelco I got needed material grinded off by the temp sender and the distributor as well as the rear bolt hole not quite lining up.
  23. c322348
    c322348
    472 doesn't use a valley cover. I think you mean the 429.
  24. Opps, yep meant to say 429 - all fixed.
    Thanks,
    Dennis
  25. titus
    titus
    Got an early xmas present from my wife tonight, a customer she was doing upholstery had it and she bought it for me! thanks hun
    Detroit racing 2x4, the guy said hes owned it for 50 years! and he was the second owner!
    He said he thought he had the linkage for it to so i found a pic and am going to get it to him so he knows what hes looking for.
    Also i pick up some ducoils one for early and one for late.
    jeff
  26. 31ford429
    31ford429
    from Florida
    cadillac **** i love it
  27. M.Edell
    M.Edell
    On the hunt for a Cragar 4x2 or Weiand WCA 408 Dual Quad Intakes for a 390 I'm gonna do for the 34.
  28. c322348
    c322348
    Anyone have an under the distributor cap Stewart Warner tachometer sender to fit a 331? I've been looking for quite a while and have struck out... Help!
  29. iammarvin
    iammarvin
    from Tulare, Ca
    A Nicson 2x4 in it's natural environment.......
  30. Mr.Musico
    Mr.Musico
    from SoCal
    great thread!
    are they repopping early cad 331/390 intakes now? this look like nos or new?
