Technical Odd Engine Code
Discussion in 'The Hokey Ass Message Board' started by AR19Elite, Aug 26, 2017.
  1. AR19Elite
    AR19Elite
    Hello all,
    I have a 1942 Chevy Special Deluxe. I thought it was the original inline six, however I have doubts. The engine for one looks more like the third gen built in 62, also the engine code doesn't match anything I can fine. If someone has even the slightest idea.
    LA029I396 on a plate by the distributor
    3701887 GM6 stamped on the valve cover
    Thank you!
  2. squirrel
    what are the cast numbers on the block, near the starter?
    Does the side cover only extend up to the top of the block, not over the head and up to the valve cover?
  3. 6inarow
    6inarow
  4. AR19Elite
    AR19Elite
    I meant to say the plate is near the starter, and not the distributor. As to the side cover I'll look when I take a pic in shortly
  5. squirrel
    Is the numbery you gave, on a plate that is attached to the engine, or is it stamped into the engine block? Look for a number stamped into the engine block, near the base of the distributor. As well as numbers that are part of the block casting, near (or partly hidden from view by) the starter.
