Odd size license plates
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 29, 2010.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Since South Carolina has approved year of manufacture license plates I am looking for a chrome frame to use with my tag but haven't had any luck locating the odd sized plate of the 30's.
    I'm sure somebody here knows of a source. HRP
  2. mikeco
    mikeco
    from virginia
    Try Streamline or Parr Automotive. I've seen them as well.
  3. seadog
    seadog
    Bob Drake has them
  4. HOTRODPRIMER
    HOTRODPRIMER
    Thanks Tom, HRP
  5. 32 Barn Car
    32 Barn Car
    from Oregon
    Get some of the old original accessory ones . They adjust to most sizes . Got mine on eBay and they also re-pop them.........
  6. mj40's
    mj40's
    I'm looking for a 1940 SC plate. I only need one. Anyone?
  7. tommy
    tommy
    The big problem is that the states were not consistent back then. There were some accessory frames that were adjustable in both directions. IIRC they were 40 Ford pieces.
    Measure your plates before you order anything. I'm trying to find a pair for some 1956 Maryland plates. I gave up on my 34 Md. plates. My truck came with 34 Cal plates and a frame but they are a different size than Md. I've see some larger frames on Ebay but they always go for more than I want to spend.
    I'm thinking of having the guy in Fla. that makes the phoney plates do some using my 56 plate numbers so that a standard frame will fit. I'd be liable for not showing the correct plates but it would be tagged and insured correctly.
    I have collected some neat frames. I even have a California Ford dealer frame with my last name. Mills Ford. I'd love to use that.
  8. HOTRODPRIMER
    HOTRODPRIMER
    That's what I will probably have to do with the '32 License plate,,5 1/2" X 12 1/4"
    Drake listed one that will work fine for the '54 wagon.
  9. dehartcarl
    dehartcarl
    Take older standard size plates, change the year, paint them the right color and take to DMV and register them to your car. Takes a little welding & body work but Iv'e seen it done many times and never seen DMV catch it.
  10. denis4x4
    denis4x4
    from Colorado
    I have the same problem with early Colorado plates. The adjustable ones don't get the job done.
  11. HOTRODPRIMER
    HOTRODPRIMER
    This is what I located on the Bob Drake web site,, HRP
  12. tommy
    tommy
    They won't fit my 34 or 56 Md plates. Do they fit your SC plates? My 32 SC plate was hard to find and more costly than the other states. "the iodine state" I bet they really jump in price now.
    I could not find any repro adjustables either. I tried an Ebay search but there are way too many modern tag frames for me to wade through them all.
  13. HOTRODPRIMER
    HOTRODPRIMER
    Tommy,the top one is close to fitting my 54 plate and I'll let you know how it works outbut none fit the 1932 South Carolina Iodine state tag,,nothing even close,,,and yeah,,they are :eek: EXPENSIVE :eek: now.
    I'm going to use a adjustable frame on the 32. HRP
  14. MilesM
    MilesM
    I got a pair of adjustable repro ones from Kanter recently.
  15. cheveey57
    cheveey57
    With the skills on this board I'm sure someone can make you what you are looking for.....................:D
