Hot Rods Odd voltage Regulator
Discussion in 'The Hokey Ass Message Board' started by sodakmini, Dec 15, 2021.
  1. sodakmini
    sodakmini
    I picked up a 1118981 12v delco voltage regulator for my hot rod. Running a 283 with a 12v generator. This regulator has 3 tabs on the outside: L, Bat, and F. There is another tab underneath that I believe is for a capacitor, although I have seen it labeled G. So… the L is throwing me for a loop. I have read that it means either Light or Load. I’m wondering if I can use it the same as an A tab.
    My question is…. Can I use this regulator?..
  2. squirrel
    get a generator from a tractor to work with it?
  3. sodakmini
    sodakmini
    Is it just a tractor regulator?
  4. theboss20
    theboss20
    The tab underneath is a A=armature tab and connects to A on the generator, F=field, B=battery and L=lights…as in a direct feed to the headlight switch for power. Yes, this is typically used on tractors and normally a low amperage output regulator…probably 15amps. A car generator regulator is usually 30amps. This will work but the low amperage will be an issue.
    leon bee and squirrel like this.
  5. sodakmini
    sodakmini
    Great. Thanks for the answer. Will find me a better one.
