1952-59 Ford Oddball Engine Swaps
Discussion in 'Off Topic Hot Rods & Customs' started by Bigcheese327, May 15, 2012.
  1. Bigcheese327
    Bigcheese327
    Curious to know what’s been swapped into these cars (especially the ‘52-‘53s) other than the typical SBF and SBC, and how it was done. I've been told an FE will bolt into a '54 by using '58 engine mounts.
    I am especially interested in hearing from anyone who swapped a 215 L6 for a 300 L6 or who has put a Cadillac V8 in one.
    Thanks!
  2. boogymn
    boogymn
    I pulled a 215 L6 out of a 52 Customline Fordor and stuffed in a 429 with C6 and 9Inch. Had to move the firewall back three inches and am still trying to figure out how to fit the radiator and find some headers/manifolds that fit. This has been a big job and cost a fortune, I can't wait for that first drive since the swap.
    Michael
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Order this book: http://shops.half.ebay.com/122noel_practical-engine-swapping_W0QQ_trksidZp2684QQmZbooks it has a bunch of info and tips that will help you out especially the chart that shows the width and length and weight of a lot of engines it also tells the locations of oil pan sumps which is always a big deciding factor.1952-53's were rear sump and 1954-59 Fords were front sump so you need to take that into account,472-500 Cadillacs have a mid-sump pan however for a lot of cubes the 455 Olds is rear sump.Cadillac Eldorados' used a rear sump pan but check out what they go for:http: http://www.ebay.com/itm/Cadillac-El...-Rat-Rod-G-body-Swap-/180882144554#vi-content some of the Cadillac suppliers have sold these in the $800 bracket as posted in some of the HAMB archives.You can probably pick up a 455 Olds for the cost of the Caddy oil pan and there are a decent amount of aftermarket parts goodies for the Olds.
  4. you might also consider the early Olds Rocket engines ( 303-324-371-394 ) I have a '56 324 in my Model A project - it has rear pan so in theory would not be a bad fit in the '52-53 ford and still gets you into a nice nostalgic engine .
  5. dwaynerz
    dwaynerz
  6. dwaynerz
    dwaynerz
    forgot to put the ;) at the end of my last comment :)
  7. rld14
    rld14
    Was talking to a guy on here who had one with a 331 Hemi in it... A swap I'd looooove to do.
  8. missysdad1
    missysdad1
    I've seen several hemi swaps in the "little books" over the years so I'd suspect it's not all that complicated. And for the "wow" factor a hemi just can't be beat...
  9. Custom_Crestline
    Custom_Crestline
    I swapped in a Y-block XD
  10. boogymn
    boogymn
    Hi Dwaynerz. I mistpoke above, I don't have a C-6 I have the really big manual that was optional behind the 429 (can't recall its name). Honestly I think my biggest problem is the lack of welding knowledge and equipment. Oh, I guess the lack of money doesn't help either. : /
  11. I just hot rodded the Y Block. 292 block, sonic checked, 312 crank, punched .080 for 317 cid, Forged AL pistons, 9.5 compression, Blue Thunder intake and 625 Road Demon. Cam is 284 110*. Added on a T5 and away we go.
  12. 54HotRod
    54HotRod
    I have a 351 Windsor with a C6 in mine, but I didn't do the swap, I just have to deal with the limited space issue.
  13. Bigcheese327
    Bigcheese327
    So you're saying a 430 or 462 Lincoln might not be a super desirable swap?
  14. JeffB2
    JeffB2
    from Phoenix,AZ
    The MEL 430-462 is very wide so exhaust clearance to steering box is a major issue,however the FE's 352-390-428's exhaust ports are high and clear the box well and you can use stock motor mounts to do it in a '54-59 in a '52-53 you will need the Speedway mounts and the FE truck rear sump oil pan.Another big plus is lots of aftermarket FE parts are available the MEL's are almost non-existent.
  15. [​IMG]
    472 cadillac 1953 ford customline
  16. dwaynerz
    dwaynerz
    a fordillac. arent the cadillac motors supposedly the same size/weight as a small block chevy? at least within a few inches/pounds anyway if i remember correctly. i think hotrod tv just built one up a few weeks ago that made over 800 lbs of torque, but it had been worked a 'little'. it also reved to around 6 grand as well.
  17. Ole don
    Ole don
    If maximum Caddy HP is desired, research the Caddy Bonneville streamliner from Spector Performance Products. It went over 400 with twin turbos.
