OEM Ford wide 5 wheels
Discussion in 'The Hokey Ass Message Board' started by gnichols, Apr 5, 2011.
  1. FiddyFour
    FiddyFour
  2. hot rod pro
    hot rod pro
    from spring tx.
    Thanks for clearing that up.
    -Danny
    Sent from the best app on the web.
  3. gnichols
    gnichols
    from Tampa, FL
    Next question... ifn I had some OEM wide 5 wheels, could the lug holes / center section be modified to fit on vintage wide 5 hubs, as those racing parts use larger wheel studs and lug nuts? Simply drill out the lug holes, or would this be unsafe? Could you modifiy the OEM wheels by welding in larger seats for those large lug nuts? Thoughts? Thanx again, Gary
  4. scootermcrad
    scootermcrad
    The holes on the stock Ford Wide Five wheels will except 5/8" studs (or bolts in some cases). I used later model wide five adapters for mine and they actually had 5/8" bolts. Wheels slipped right on. But, I didn't like the bolts and wanted to keep the lug nuts all the same, so I removed the bolts and set the adapters up with press-in 1/2" stud.
    But in short, yes, the lug hole sizes will accommodate the later 5/8" thread.
  5. gimpyshotrods
    gimpyshotrods
    X2. I just slipped a 5/8" wheel stud through a hole in several of my spare wheels. Goes right in. No modification required. The cone of the lug nut should still have plenty contact area.
  6. gnichols
    gnichols
    from Tampa, FL
    Thanx guys. That's good news. I've been "scheming and dreaming" on a future build that uses 60's era racing parts, like those used on oval track modified coupes. But I've also considered getting automotive style wide 5 adapters to use on my 27 truck, too, for other types of wide 5 wheels. Gary
  7. gimpyshotrods
    gimpyshotrods
    If you are planning on running adapters to get from the smaller 5-bolt pattern, up to the wide-5 pattern, I would recommend against the heavy steel ones found at the race suppliers. Instead, a set of aluminum ones, such as the ones that **** Spadaro sells. His site can be found here: http://www.****spadaro.com/catalog.htm
    He's also here on the HAMB. His handle is his name. Dude knows his stuff.
  8. gnichols
    gnichols
    from Tampa, FL
    Roger that. Gary
  9. safari-wagon
    safari-wagon
    Does anybody know where I can get a 16x3-1/2" rim as a mate to the one I have?
    If ya do, I'd appreciate a lead on it.
  10. v8 garage
    v8 garage
    Did not find the adapters in his online catalog. What page are they on?
    V/8
  11. gimpyshotrods
    gimpyshotrods
    Page #13, 5th column, 4th product down.
  12. Rocky
    Rocky
    Classified Editor
    I have a pair of 16X 7" with a band welded in to widen the old stockers...going to use them on my old Winters quickchange with 5/8ths studs..hope my 39 ford hubcaps will clear the center hubs.
    Will use stock 4 inchers on the front with adapters to clear my later disc brakes.
    Spadaro's adapters start at $145
  13. lowsquire
    lowsquire
    from Austin, TX
    see my earlier post. I dont know how available the prefect rims are in the US,but they are everywhere here..
  14. elmitcheristo
    elmitcheristo
    Does anybody have any pictures of the "high clearance" wheels that they can post? I have never heard of them for the wide 5 until this thread and would really like to see one.
    Thanks in advance,
    Mitch
  15. 117harv
    117harv
    Here are some pics.
  16. dirt slinger
    dirt slinger
    Since this is a wide 5 thread can any of you fellas tell me what wheel this is?
  17. gimpyshotrods
    gimpyshotrods
    They are 39-41 3/4-ton pickup wheels, and are 16x5".
  18. gnichols
    gnichols
    from Tampa, FL
    I'm glad this thread bubbled up to the top again. FYI all, and beware, ebay seller "calouisiana" who is from the Lafayette, LA area and sells used wheels sold me a set of 4 wide 5 rims. Well, I paid for them at least. After months of delays, I got one good rim and one useless super decrepit / damaged one. Now I have to do the paperwork thru my bank to try to get my bucks back. Gary
  19. Gary Addcox
    Gary Addcox
    I really like wide 5's in the right application, but the food at Prejean's in Lafayette is to die for (or kill for), whichever comes first.
