Technical Offenhauser 5694 Dual Quad Intake
Discussion in 'Traditional Hot Rods' started by Artwoodie, May 4, 2025.
  1. Artwoodie
    Artwoodie
    I have a 383 (SBC), with the 5694-intake installed. Running two 500 cfm AVS2's. In front of the front carb are two pipe threaded ports. How are they different from each other. I'm using the one to the left for a mechanical liquid filled temp gauge. The one near the thermostat housing I use for my dash electric temp sending unit. My electric fan sensor is in driver's side head. Is the correct????
    Art Klein
  2. swade41
    swade41
    from Buffalo,NY
    I don't think there is a difference, I use the one closest to valve cover for temp guage, the other I have blocked off.
    Tow Truck Tom likes this.
  3. 1biggun
    1biggun
    Should not make any difference . I doubt the coolant is a different temp only 2 " apart from each other .
