Offenhauser Flathead offset generator advice???
Discussion in 'The Hokey Ass Message Board' started by daddio211, Apr 24, 2013.
  1. daddio211
    daddio211
    Fellas, I need some input. I spent the evening in the shop and I'm trying to sort out an issue.
    My 8BA flatty's heads and intake are Offy. I also bought the Offy offset gen bracket, but being cast aluminum I have a lot of concern about tension on it and if I should be bracing it. Does anyone know if the upper hole on the head is made for a mounting bracket for this purpose? I suspect the lower holes are to mount the coil.
    Thanks for your help!
    Sent from my DROID device using the TJJ mobile app
  2. 59ab
    59ab
    No bracing needed. The upper hole in the head is for the bolt that holds the distributor in. You are correct on the lower holes. They mount the coil bracket. Hope this helps. Eddie
  3. daddio211
    daddio211
    Thank you so very much Eddie!
  4. pwschuh
    pwschuh
    Yea, as long as you don't go crazy on your belt tension, it should be just fine.
  5. daddio211
    daddio211
    I appreciate you two. Just makes me a little nervous as the generator is heavy as hell already! If others have run them without issue and I keep belt tension appropriate looks like I'll be trouble free.
  6. alchemy
    alchemy
    Yep, as long as you have a big socket/spacer to spread the load on the mounting bolt, you should be home free. :)
  7. daddio211
    daddio211
    LMAO, thanks Alchemy. Couldn't find my fan for the picture.
