Technical Offenhauser Heads ID
Discussion in 'Traditional Hot Rods' started by Model A Mark, Jan 30, 2026.
  1. Model A Mark
    Model A Mark
    from dallas
    hey guys, can anyone tell me about these heads .
    I cant find any like em on the web, and Ive been trying to contact Offenhauser with no luck.
    The thermostat housing surface is horizontal, not on a angel like all others .
    Im thinking Marien applications maybe,
    Thanks for the input.
    SPEC, Fordors and Toms Dogs like this.
  2. Toms Dogs
    Toms Dogs
    from NJ
    I've an Offenhauser head like you have on the p***enger side, dog-power_8-2014.jpg and one that has the t'stat housing that's parallel to the machined face on the driver's side... they have been installed like this for the past 30 years.:D:rolleyes:
    SPEC and Model A Mark like this.
  3. Model A Mark
    Model A Mark
    from dallas
    These are the first ive ever seen
    Toms Dogs likes this.
  4. lostn51
    lostn51
    from Tennessee
    I’ve seen a pair like those but I can’t remember what the feller said about why they were like that. I’d like a set like them if I could find some at a decent price.
    Toms Dogs and Model A Mark like this.
  5. Model A Mark
    Model A Mark
    from dallas
    Im sure someone here knows about them.
    lostn51 and Toms Dogs like this.
  6. Toms Dogs
    Toms Dogs
    from NJ
  7. Model A Mark
    Model A Mark
    from dallas
  8. lostn51
    lostn51
    from Tennessee
    I do know that the feller told me that they were early 8BA heads and if you put the factory water neck on them they would be offset to run multiple carburetors and offset generator.
    That’s all I got….
    Model A Mark likes this.
  9. Not sure, but I did a quick run through my favorite internet search engine, and I need to know why brand-new finned aluminum flathead heads are almost $1700 bucks these days. WTF...
  10. tubman
    tubman
    The tariffs have made it economically unfeasible to make them in China.
    Beanscoot and Pocket Nick like this.
  11. Well here's hoping my current ones don't have any electrolysis damage like my Edelbrocks ended up developing, I added more grounds and stopped running straight water after that incident. Geez.
  12. banjorear
    banjorear
    Can't help with the OP's original question, but they would help in some situations.
    Are/were there any heads made in China? Both of the big players, Offy & Edelbrock, have been made in the USA for as long as I can remember.
  13. If you're looking for new heads, I'd checkout Summit Racing for Edelbrock heads. They are about $1000 - not cheap, but not $1700 either:
    Edelbrock 1115 Edelbrock Ford Flathead Cylinder Heads | Summit Racing
    Pocket Nick likes this.
  14. 19Fordy
    19Fordy
    I had a set of those 8BA style OFFY heads that I bought used for $5 in 1963 off a marine engine.
    Although they were used on marine engines they can be easily used in cars because they are horizontal.
  15. Blower Manifold: Hey, does anybody happen to know who made the blower manifold shown in the OPs original picture? It looks like an H&H product . . . just checking if anybody else happens to know?
  16. tubman
    tubman
    You might try running a magnesium (NOT zinc) sacrificial anode.
  17. Model A Mark
    Model A Mark
    from dallas
    I got the manifold and blower rear cover from Mike, both are Navaro
  18. Model A Mark
    Model A Mark
    from dallas
    Thanks man
  19. Model A Mark
    Model A Mark
    from dallas
    Yea they help rout the water around the blower case
  20. banjorear
    banjorear
    I also run water and have great success using a product called No-Rosion.
    Here is their site:https://www.norosion.com/productpage.htm
    Their No-Rosion product when used with purified water, prevent electrolysis damage. They recommend a cleaner first that will de-rust the block and etch the cast iron, but leave br*** and aluminum alone.
    Living in the northeast, I need to drain my system due to an unheated garage. I know it works for the water comes out exactly like it went in. No rust, gunk, etc. I've swap aluminum heads in the two years of using it and there is zero signs of electrolysis.
    Get out their site and read their tech. info page. Very informative. Highly recommended.
  21. Beanscoot
    Beanscoot
    Any particular reason not to simply run good old green antifreeze mix in the engines?
  22. ClutchDumpinDan
    ClutchDumpinDan
    They pop up every once in awhile. But doesn’t seem to be alot of them around. Theres been a few threads about them, could only find one but all the pics are gone. The set I had I sold to @Good`Rockin Daddy
    Model A Mark and Toms Dogs like this.
  23. banjorear
    banjorear
    Water cools better than antifreeze and can't run it at races like TROG, etc.
  24. 29Sleeper
    29Sleeper
    from SoCal
    Short run specialized part. Falls into line with current 4 cylinder Model A heads at $7-800 each.
    Vic Edelbrock built a casting plant to make his products and has branched out to many other industries for it.
    https://edelbrockfoundry.com/
    Of course "Edelbrock" as a family company no longer exists. It's part of Comp Performance in Mississippi. The casting remains in CA but I'd venture it'll move too.
  25. 51 mercules
    51 mercules
  26. Model A Mark
    Model A Mark
    from dallas
  27. 51 mercules
    51 mercules
    You're welcome!
  28. Good`Rockin Daddy
    Good`Rockin Daddy
    from Germany
    And you did that very well. ;)
    ClutchDumpinDan likes this.
