Offenhauser valve cover later Chevy 6
Discussion in 'The Hokey Ass Message Board' started by scoop, Jul 10, 2012.
  1. scoop
    scoop
    Anybody have any issues installing one of these?Holes don't line up,some are about a third of a hole off.
  2. LIL ANGE.
    LIL ANGE.
    from Long Beach
    what year is your is 6? do u have pics
  3. propwash
    propwash
    from Las Vegas
    235? 250? 292? 228/248/270/302 gmc?
  4. scoop
    scoop
  5. LIL ANGE.
    LIL ANGE.
    from Long Beach
    i think those only fit 235's n 250's, i could be wrong
  6. Jcar
    Jcar
    from fargo nd
    I really struggled with one on a 292 also. had to oblong the holes with a die grinder and grind on the inside of the cover to clear the retainers but I did get it to work.
  7. Jethro
    Jethro
    Sometimes when you use an aftermarket valve cover on the 250-292 you need to use a spacer between the thermostat housing and the block because of interference. That could be your misalignment.
  8. Dakota
    Dakota
    from Beulah, ND
    I h ad to file a few of the holes to make it fit on mine. they asrent the most accurate pieces around. I used Studs to install mine.
  9. 250 and 292 use the same head.
  10. Snarl
    Snarl
    The Offy cover for the 194-292 engines is the worst fitting of all of them. A better choice would be the Clifford version, or the Mercuiser ones. Or get an adapter to use the 235 style Offy cover.
  11. jalopy45
    jalopy45
    Start by laying the gasket on the valve cover if it's off there but lines up on the head, the problem is..............? The thermostat housing shouldn't interfere with the cover. Sometime manufacturers don't keep up with quality control. :)
  12. Lone Star Mopar
    Lone Star Mopar
    [ . Sometime manufacturers don't keep up with quality control. :)[/QUOTE]
    As much as they cost Offenhauser should have somebody comeover and install the damn thing for you...overpriced ****
  13. scoop
    scoop
    Thanks for the advice!
  14. tlowe
    tlowe
