Technical Offenhouser valve covers from Speedway
Discussion in 'Traditional Hot Rods' started by 46international, Aug 29, 2017.
  1. So I sprung for the high dollar valve covers $320 from speedway for my 292 Y block. After making up longer studs to mount them they were looking pertty good, that is untill I went for a ride. Oil all over the place, both covers were leaking from the front and rear. Checked the gaskets and saw that there was no clamping of the gasket. After looking closer I could see that the gasket surface was not flat! looks like about 3/32" lower in the center of the cover. Luckly I just bought a mill from a buddy and could fix them but it ****s to have to repair a set of brand new $320 valve covers. Has anyone run into this?
    ls1yj, Truck64 and loudbang like this.
  2. sorry for the rant.
    biggeorge likes this.
  3. Fordors
    Fordors
    Rant? Sounds completely justified to me.
    Fern 54, mad mikey, Paul B and 7 others like this.
  4. 6-bangertim
    6-bangertim
    Speedway AND Offenhouser won't know you got a POS set unless you sent them back - or at least sent them pics of how BAD they are. For OVER 3-bills, I'd be sending those turds BACK! Maybe try your luck with a MOON pair next?
    Some companies just don't get it - the MORE we spend, the higher our expectations... :(
  5. trey32
    trey32
    I will buy used swap meet garbage before I buy speedway anything...
  6. jimmy six
    jimmy six
    geesh.................... call them, they have always been good to me. not my favorites but still. this is Offys fault not Speedway. I would included both in an email or letter.... The Offy manufacturer will make them good.
  7. Deuces
    Deuces
    What a shame.... :(
    loudbang and 46international like this.
  8. LM14
    LM14
    from Iowa
    That's an Offy problem, not a Speedway issue. Send them both and email and they will make it right.
    Hatchet, mikew, swade41 and 4 others like this.
  9. crminal
    crminal
    I'm not a machinist, but I wouldn't mill ****. Send them back.
  10. Tim
    Tim
    from KCMO
    Yeah I'd just call and get a new set. They will absolutely let you return a defective part.
    Also offy makes them speedway is just one of the many places that sell them.
    46international likes this.
  11. oldolds
    oldolds
    You probably did the right thing, fixing yours. Chances are a whole production run was bad. You would have just exchanged a set for another bad set.
    You should message Speedway and Offy, tell them about the problem. Also that you repaired them. You might get a job fixing all of them.
  12. milwscruffy
    milwscruffy
    Put a straight edge on the surface, take a picture and contact Speedway at the very least. I've had good luck with them in the past and if they want to send you a replacement pair, get a hold a tech guy there, get his name and have him physically check them before shipping another pair out. I've had this done in the past with more than one vendor.
    verno30, mad mikey, loudbang and 2 others like this.
  13. burl
    burl
    from Minnesota
    wall section in that area probably isn't to thick.If you try to flatten the surface,if its out that much you might not have to thick a wall left.Id send them back but you may find other sets aren't much better.Some of the old corvette sets I have don't check much better.
  14. Gman0046
    Gman0046
    What more did you expect from Chinese parts made by small children? Speedway is the last place I'd purchase parts from.
  15. 2935ford
    2935ford
    Yup, don't mess with them.....return, pronto!
    verno30, loudbang and 46international like this.
  16. Texas Webb
    Texas Webb
    Like was said Offy made them,Speedway sells them.
  17. williebill
    williebill
    Or send 'em back, and run real T-bird covers.
    51 BIRD, loudbang and 46international like this.
  18. sloppy jalopies
    sloppy jalopies
    the cheapest manufacturing price vender made them for offy.... china ?
    if yours are BENT you can bet they whole batch are...
    my speedway 351 v covers were ok... just lucky.
  19. denis4x4
    denis4x4
    from Colorado
    Last time I checked, the Offenhauser factory was on Alhambra Avenue in Los Angles and never saw any small children operating machinery.
  20. steinauge
    steinauge
    from 1960
    I have bought a LOT of Offy stuff over the years and it has all been good.I would send those right back.
  21. Tim
    Tim
    from KCMO
    Yeah Offy is in America with grown *** adults making their product.
    Randall, mctim64, Saxman and 4 others like this.
  22. BJR
    BJR
    Then they must be getting senile to send out **** like that.
  23. 6inarow
    6inarow
    Not necessarily speedway has been known to rip off other vendors/producers and produce and sell it as their own.
  24. Texas Webb
    Texas Webb
    Was not aware of this.
  25. mike bowling
    mike bowling
    Whatever your choice of action, I hope you walk away satisfied ( at least mostly). I've gotten jammed with "NEW" parts that are junk right out of the box- big dollar items? Go to battle. Smaller stuff ( under 100 bucks?) with shipping and re-stocking charges , it's not worth getting worked up over.
    Good luck with it
    mad mikey and 46international like this.
  26. fordcragar
    fordcragar
    from Yakima WA.
    If you touch them with a mill, you own whatever happens to them. You might get lucky and be able to fix them, but I'm with everyone else. Call Offenhouser first, and ask them what they want you to do with them. If they won't do anything, send them back to Speedway.
  27. Torana68
    Torana68
    from Australia
    new to me as well are you confusing Speedway with So-Cal maybe?
    Anyway send them back or at least tell them in case they (Offy) have a machine or operator fault, looks like they have a QC problem.
  28. Gary Addcox
    Gary Addcox
    I'll drink to that.
  29. Gary Addcox
    Gary Addcox
    Thanks for warning the rest of us about your problem. Many rodders on the HAMB have bought what turned out to be real **** from Speedway.
  30. Gman0046
    Gman0046
    If grown *** adults are turning out **** like the OP received maybe Offy ought to switch to China for their manufacturing of parts. Manufacturing of valve covers isn't rocket science.
    loudbang, 46international and 6inarow like this.
