Hot Rods Official 1959 Chevy Apache Build Thread
Discussion in 'The Hokey Ass Message Board' started by 1959apache, Feb 17, 2010.
  1. 1959apache
    1959apache
    Yeah it is A LOT of stripping and yes, it is epoxy. I had to get the rust under the paint that was shot on and I can't afford to get this thing sand blasted.. Total for getting the interior stripped and put into epoxy was right around $90. A hell of a lot better than $300-500 for sand blasting and then another $300-500 for epoxy primer. One day in the future I will shoot this whole thing again and get some decent paint on it, right now it will be in epoxy, while I work on other stuff on it... like finishing up the body work. She is getting close!
    I have your diagram btw but my scanner is down and pictures turn up ****py. I might have to do it in Microsoft paint!! :D:D:D
  2. Saxman
    Saxman
    Your pics are giving me flashbacks. I just did all this same stuff over the past couple of months. It's a lot of damned work!
  3. 1959apache
    1959apache
    Yeah and not fun either...
    I just found out the p***enger side step is trashed.... I started blowing through it with the wire wheel just cleaning the scale off of it... son of a....
    I put in an order to cl***ic parts for stuff on Lucy (my '64) and some sheet metal here on the '59... I will have to call back and have them add the step too... It bums me out a little... They arent exactly fun to repace as I recall.
    I decided to then go to the drivers side and start stripping that and got a lot done there. I still need to pop the door off, polish the rest of that **** on there then I can get that side shot in some epoxy primer. I think I will go ahead with my plans and get the floor done anyway or at least start on getting the little metal work finished that needs to be competed before the interior can go back in.
    The saga continues :D
  4. 1959apache
    1959apache
    Here are some shots from tonight... We landscaped the back yard most of the day, so I didn't get a chance to do what I really wanted to do.
    This thing is going to be bad ***, just saying....
    Is it just me or do I look like a WWII bomber pilot??
    Here are some shots of the primer:
    Tomorrow I will get your stuff dubie, I have it out in the garage still.. I will be working on putting everything back together, so that will be done finally. Thanks for being patient. More to come tomorrow!!!
  5. dubie
    dubie
    Thanks for taking the time to do that for me bud. You're right, your truck is going to be bad*** when it starts rolling again. Here's a quick shot of where I'm at with mine right now
  6. 1959apache
    1959apache
    Sweet! It's looking good, any progress lately? I have been checking your thread, but haven't seen a whole lot.
    Here are the shots of the drawings... let me know if you have any issue reading them or whatever. I am colorblind to red and green so learning how to use a meter is a must for me... I did all of this just using the meter and reverse engineering the switches, so to speak. So some of the colors may not be accurate.. I will try to find the names on the wire, but I have them bundled.... Let me know if you don't see something that needs to be there...
    The ignition switch is a spring loaded start (I eliminated the start ****on) so if you are using something different then I would change how it is set up from mine and follow the instructions in the Rebel Wire kit:
    Here is the light switch (same switch that 55-57 chevy p***enger cars used). Notice I didn't use all of the spade terminals... I didn't see a need to add a bunch of **** I was not going to use yet. I didn't have the dome light hooked up at the time of wiring this... I can tell you where it goes later when I get it figured out... which shouldn't be difficult. Some of the spades not used are for the 235 that was in it... I am now running HEI on this since I had it sitting on the shelf... Here is the shot of the drawing:
  7. 1959apache
    1959apache
    Well I didn't get a ton of **** done tonight, but was able to do about 3.5 hours of yard work and landscaping, walked the dog, went out to eat, and cleaned up the cab... I installed the two switches that I was drawing up for dubie... I then dropped the main gauge cluster out to install the new face and nice chrome bezel... I will do that after I am finished grinding in there.... I shopvac'ed the cab out... a lot of **** in there... and I prepped for what is to come tomorrow (patch panels and more welding, fixing of the cab in certain areas)... I will also drop the column out of there tomorrow in preparation for doing the floors.... I will also have to remove the gas pedal and maybe even the brake pedal (dont want to remove it, but I need to figure out the ratio to fix it. Plus I ****ed up a ****** cover screw... so now I have to dig around in the nasty *** shop vac dirt to find it... here are some shots:
    I also found out that one of my wires got chaffed and was shorting out on the back of the dash, thus draining my battery... I am glad I found it!
  8. dubie
    dubie
    Thanks again for the diagram. I'm going to double check it against mine and see how close they are.
    I stopped updating my build thread because I was the only one looking at it, it seemed haha. We are a few days away from firing up this new engine. After that, all it'll need is paint
  9. 1959apache
    1959apache
    I was lurking in the shadows. Make sure you post something on the engine firing! That will be cool.
  10. 1959apache
    1959apache
    I got my parts in for the '64 C10 (speedo cable and other random ****) and my patch panels for the '59... I will start dismantling the step tonight and with any luck get the new step prepped to put in. It would be nice to get it all the way in... but I shouldn't push it... I also will be replacing the lower door hinge part of the frame (where it bolts up) so I can adjust the doors a lot better. More pics tonight
  11. chaddilac
    chaddilac
    Jambs look good!!!!! I liked it in bare metal also!
  12. dew468
    dew468
    from Austin, Tx
    I stopped posting for the same reason. seemed like no one was even looking at it. i will be posting again soon anyway, lol.
  13. Buzznut
    Buzznut
    Looking great! I wish I had the time and motivation to do all of that right now, but I'm itching to drive it. Maybe this winter....
  14. Shane Spencer
    Shane Spencer
    Lookin good buddy
    Sent from my DROID device using the TJJ mobile app
  15. 1959apache
    1959apache
    Well I think that the ceiling is pretty close.. I won't really be able to tell a lot until I get on the roof and make sure everything is sound.. That will be this winter probably... Here is the roof:
    It doesn't look like much, but I got the rear supports welded back onto the back of the cab and the floor... since they were just hanging there.... Not really good....
    Here are the shots of those, I will clean them up later.. One kind of burned through so I had to compensate by starting out with a larger diameter... plus I couldn't see in my welding helmet, damn battery is dying:
    I started on drilling the spot welds out of the step.... A lot of spot welds for this thing... holy ****... I will have to find out where the spots are on the main bottom part of the step... I may saw zaw some **** to make it faster.... I wish they would show themselves... Anyone know where they should be? Everything else on the face is loose and it will fall out when the bottom part of the step is done, I just need to cut the welds. Here are the pics:
  16. 1959apache
    1959apache
    Thanks guys, it seems like all of the 55-59 Chevy guys restoring one just posted today... WEIRD lol.
  17. dubie
    dubie
    I keep track of this build, along with Taylor Crawfords and Buzznut all at the same time. It's interesting to see how many similarities and differences there are in each individuals build.
  18. Indy47Caddy
    Indy47Caddy
    Hey Scott, forgot to mention earlier... some advise I was given from Dave Kinnaman (the guy that built my 55) was to make sure I hang and align my doors on my Cadillac before I replace the metal in the door sill. He has had cars come in his shop where the bottom of the doors s****s or the doors can't be adjusted for proper fit because someone replaced the door sills at the wrong height.
    Not sure how trucks are for door clearance with the door sills, nor how the doors are adjusted for fit, but you might want to take that into consideration before welding everything in place.
    Jason
  19. 1959apache
    1959apache
    Yeah I do too, I had a routine down for a while where I would check everyone's even the newbies to the forum. You never know when you will see something cool...
    Cool thanks for the info dude! I will do this for sure here. I got a lot done tonight, so I will try to get the door hinge pocket replaced first then just tack the step in, hang the door and check.
  20. 1959apache
    1959apache
    I started off tonight by removing the step (the saw zaw helped a lot) and got the replacement step out to check to see how close it was… This step was so rotten in places that when I started to drill the spot welds the steel was thin enough that it just tore out so I didn't have to drill anymore.... Good thing I am replacing it.
    I then started t******* it up and got it pretty close. I will have to go through and clean up the flange of the original setup and then go through and get everything trimmed and fitted. I will have to also take a look at the hinge pocket and replace what I can there with my patch panel. Does anyone know why the hell they would put a flange on the forward and rear part of the step (where it ****s up to the door jamb)?
    Here are the pictures:
  21. Buzznut
    Buzznut
    Nice, clean, strait metal...love it. I need to replace my drivers step one of these days. Was it difficult, easy? Scale of 1 to 10...
  22. 1959apache
    1959apache
    Thanks Buzz
    for you.. we will go with 11
    just kidding :p
    Well the hard part is finding the spot welds (had to strip the paint off to find them), I have one of the stepped drill bits... so I went ahead and predrilled with a small diameter all of the welds I could find (so I didn't burn up the $14 bit on the first few), guessed on the rest and was correct. The beauty of the stepped bit is that I can go as large as I want, so if the original bit walks then I don't have to worry about anything. I just pop the ones that are close enough with a screw driver... The ***** were the ones on the horizontal face and the supports for the floor. I used a saw zaw once the drilling was finished to easily remove the step (cut it in half) so I didn't bend all of the sheet metal that was good on the floor/framework to the step.
    I have about 3 hours into it as of right now... it is just a lot of time consuming work. I think there were 40 something spot welds just holding the step in itself, not to mention the ones I couldn't find that I just cut out. I would say about a comfortable 6 to 7 maybe just because of how much time it takes.
  23. 1959apache
    1959apache
    Oh and I spoke with the parts guys and they said that even the step patches, like the one in the pictures, even made in the USA have that weird flange thing.. I am guessing that when people remove them they just cut the bottom flange out and that piece goes along the back of the steel instead of how it was originally made. Since I salvaged some of mine I may reuse it... so that means the flange has to go.... YAY..... more work :D
    Also, as a side note... waaay earlier in the thread (when I first got the truck in 2009) the shoddy patch work on the front fenders was done by the kid that stole a bunch of stuff (money, collectibles, etc.) from me when he was living in my house.. He went to Wyotec and I think he wasted his money... I have the new patches and will install them the correct way and make them look good. That will come later after I drive it for a bit.
  24. Buzznut
    Buzznut
    Funny guy :rolleyes:
    Yeah, with the little ****py box welder I have, 11 for sure.
  25. 1959apache
    1959apache
    Most of the hard work is getting the patch to fit and look right.. I can tell you right now I will have to adjust this thing a lot, so no big deal, you can do it.. you have the skillset I promise, if all else fails use a BFH
    I trimmed this thing up tonight, it took a lot of in and out with test fitting, but I found where my problem areas were and took care of most of them. Now I am going to have to mess with the base material on the floor and all of the little flanges to get everything where it needs to be. Here's another hour and a half gone...
  26. 1959apache
    1959apache
    Well started working on the door hinge, it went swimmingly. :D First time that has EVER happened. I cut it out and decided instead of making more work I would cut up the patch to match what I cut out so I could ensure that the patch was accurate. The patch that I received was a little off anyway, so I was kind of forced to do it this way. I think it turned out pretty nice, I don't think I could have done any better.
    Here are some pictures:
  27. farmer12
    farmer12
    Nice work Scott, looking good.
  28. dubie
    dubie
    I've never used an entire patch panel, just what I needed to make it work. You did an exceptional job replacing this patch bud. Good job
  29. dew468
    dew468
    from Austin, Tx
    you did the same as I did, cut the patch. I have yet to use a whole patch. they are always oversized, which I like so I can cut it to fit how I want.
  30. 1959apache
    1959apache
    Thanks guys! We spent all day on the lake and were beat. Then I saw that the Saturday car show was down at the old dog n suds so I took the c10 down there just for fun. I got some info on a pin striper and had a couple more offers on the truck, which stroked my ego a bit :) I will finish up this patch to tomorrow, hang the door, and get the step in
