Customs Offy 1075 Dual Intake Generator Fitment
Discussion in 'The Hokey Ass Message Board' started by Working Class Zero, Feb 15, 2024.
  1. Working Class Zero
    Working Class Zero
    Will a stock generator fit in stock location with Offy 1075 Dual Intake? I have a 1950 Shoebox with 1950 Flathead. I have a Powermaster Alternator (the one that looks like a generator) and wondering if it will fit in stock location or do I need the Powermaster "Shorty"? anyone running this set up? Offy 1075 Intake, dual Stromberg 97's and generator in stock center location on 1949-51 Flattie... I do not have the intake in hand yet obviously...
  2. It will not fit at 12 o'clock, it will need to be mounted off center.
  3. Working Class Zero
    Working Class Zero
    As in the off set bracket? I see the Offy 1075 gen mount is off center as well...
  4. Working Class Zero
    Working Class Zero
    And will the "Shorty" Powermaster fit?
  5. Could not say for sure on the short version. So maybe it will. Stock generator will not fit so go from there. Cast in mount is off set to the driver side so it could also play hell with cooling fan location as well. Why they did this I could not tell you.
  6. Working Class Zero
    Working Class Zero
    does anyone know why cast in mount is oss set to drivers side on off 1075? and what issue if any it will cause with fan?
  7. BJR
    BJR
    Why do you have 2 threads going on the same subject?
    Just Gary likes this.
  8. Working Class Zero
    Working Class Zero
    Better question perhaps:
    Is anyone running a Offenhauser 1075 Intake with dual Stromberg 97's and a Powermaster in stock generator position?
